5.3L vortech
5.3L vortech
i am wondering about the 5.3L truck engine
#1 is the 5.3 the LQ4?
#2 can i get 408ci out of the LQ4?
reason im asking is, i have a 2000 gmc sierra with a 5.3Litre engine and i wana possibly take this motor out, make it a 408 and put it in my camaro. let me know whats up guys, thankyou in advance
High revving 327
How do you propose to make a 327 that revs to the moon?
the 5.3 is the same stroke as a ls1/ls6 with a smaller bore, so RPM potenlial is less.
I would, however suggest putting a 4.8L(05+) crank in an LS2 or LQ9 block for a true 327(5.4L), well almost 328 actually, with a 4" bore and a 3.26" stroke. almost exactly like the original 327(4"x3.25").
or, you could just bore the 5.3 out to 3.9, and put a 4" stroker kit for a ls1 in it, and have a nice torquey tire scorcher.
I don't know how much extra a 6.0 block would cost, but If I was going to get a stroker kit, and I was not limited by any racing rules that limit displacement, I'd go ahead and get the bigger bore block. Or even go for an aluminum LS3 if it's going into a car that didn't have an LS originally.
But budget wise, it would probably give you best bang for your buck to put a ls1 stroker kit(3.898x4") since these are the most available kits on the market, and probably cheaper than finding a bigger bore engine. I don't think the 5.3 block will take much more than 3.898 bore. Maybe 3.903".
To the OP ,,,,,,,I think You're thinkin of the LR4 which is an aluminum 5.3L and to put a 4.8L crank in an6.0 block would'nt work without getting custom pistons that had the proper compression height ,,,,,,,,,,it would be a really torquey engine tho . Go to Hot Rod mag and search "The 350 Chevy Should have made" ,,,,,,2 guys into engineering and physics ,,,,,,,took a 400 sm block bored it .030" over (4.155") and stuck a 307/327 crank (3.25") in it with Ford 6cyl 300ci rods narrowed and 58cc aluminum heads , stock cam , holley or a quadrajet , GM hei and LT's and engine made 435lb. ft. and 412hp on pump 87 oct at the crank ,,,,,,,not too bad
