317 HEADS for boost?
Old 05-08-2012, 10:18 AM
I write checks with my mouth that my ass can't cash
00blacka4's Avatar
Default 317 HEADS for boost?
I have some 317 heads i wanted to use on my turbo build i was wondering if there is anything wrong with using these besides the deck height, will the valves be okay and everything ?
Old 05-25-2012, 08:57 PM
scidav87's Avatar
I run 317 on my twin turbo 408 using E85 and have regularly hit 18 pounds of boost with stock valves. Using LS9 head gaskets. No problems at all. I would highly suggest stainless valves to be safe though. I'm installing some now before I break a valve.
Old 05-25-2012, 08:58 PM
scidav87's Avatar
I also know people hitting 24 pounds of boost with them all the time. Also using stock valves.
Old 08-11-2012, 02:22 PM
JoshuaGrooms83's Avatar
what would one get to use 317 heads on an ls1?
Old 08-11-2012, 08:59 PM
scidav87's Avatar
Nothing. They bolt on just like any other LS head. I run LS9 gaskets with them for boost.
Old 08-12-2012, 02:39 AM
how high of boost would you go to get 550ish hp with a T76 .81 turbo on a stock LS1? good tune and all
Old 09-21-2012, 02:26 AM
bumpity
Old 10-12-2012, 08:56 PM
anyone? any boost numbers?
Old 10-15-2012, 04:06 PM
GMtechmatt's Avatar
the 317 heads flow great out the box and ported forget it there a good cylinder head and the valvetrain holds up good as well
Old 10-15-2012, 05:55 PM
thats what i keep getting on them. they seem to be the go to heads for affordable heads for boost. im 90% sure i want to go with 317 heads. I read really good things about them from mild setups to pretty crazy HP numbers. Im going to stick to about 10psi myself.
what i found odd is that if i go with 317 heads, according to the CR calculators, using even .040 cometics gaskets, the CR isnt that much lower on a stock LS1.
heres some calculations i got
with 317 heads 71cc, stock gasket .058, 9.6:1 CR
with 317 heads 71cc, LS9 gasket .051, 9.7:1 CR
wtih 317 heads 71cc, Cometic .040, 10:1 CR (thats 10 even. not 10.1:1)
so with that added in there, im probably going with 317 heads. also gonna do a cam with them to make up any possible low end lose. not sure if i should go with the LS9 gasket or go .040 for more optimum quench.
still wondering if anyone has expreienced boost numbers on these heads. perferably without meth in the mix. or E85 lol
Old 06-17-2013, 09:04 PM
still looking for a little more experiences with these. I got a set of 317s now sitting in my garage while I wait to get a custom turbo cam from tick.
Old 06-20-2013, 10:50 AM
Sales@Tick's Avatar
Just remember that boost pressure is not 100% relevant to cylinder pressure and does not directly correlate to the amount of power being made. Boost pressure is just a measurement of how much residual pressure is left over in the intake manifold where it's measured. Boost pressure is a measurement of the pressurized air mass that the motor cannot consume because it does not have enough volumetric efficiency to take into the cylinder all of the air mass that is available. Thus leaving what is "left over" in the manifold to be measured by the map sensor.
So if someone says, "I run 25psi of boost on 317 heads", that doesn't necessarily mean that the next guy can go out and crank 25psi on his boost controller and expect his heads not to lift.
Old 06-20-2013, 07:09 PM
I do understand that part. plus I don't plan on boosting past 15psi. im limited to 2 bar map and a 98 PCM. so 14.7ish psi is the most id put down the engine.
I just want to make sure moving from my stock 98 ls1 heads to 317 heads on 12ish psi would be worth the trouble? with a larger cam I understand the flow characteristic's would be better especially up top, but id lose some low end torque but not much with proper gaskets and a good tune.
Old 06-21-2013, 05:05 PM
Sales@Tick's Avatar
I don't see you losing any power down low.
Old 06-21-2013, 05:27 PM
MillsMotorvation's Avatar
Thats helped me in a lot of ways Martin@Tick. I was wondering why my 5.3&6.0 show more boost with the same set up on my 408. 408 is using more of the air!
Old 06-21-2013, 09:40 PM
awesome, cant wait to get that cam to get that underway
Old 06-24-2013, 05:35 PM
Sales@Tick's Avatar
Feed me feed me Seymour!
Quick Reply: 317 HEADS for boost?
