ZR-1 blower. Anyone know how to disassemble one?
Old 05-09-2012, 09:54 PM
Greg Good's Avatar
Default ZR-1 blower. Anyone know how to disassemble one?
Thanks!
Old 05-09-2012, 10:05 PM
veee8's Avatar
Yup, sure do...........
Old 05-09-2012, 10:33 PM
Greg Good's Avatar
Interested in helping?
Old 05-09-2012, 10:35 PM
3rdCoastPowerSports's Avatar
ha thats funny... if i had ever done one i would help but nope never. free bump though
Old 05-10-2012, 07:36 AM
veee8's Avatar
What do you need to take apart, the rotor pack? I had to make a special puller to get the inner hub off, make sure you mark the hub to the rotor shaft. There is very little splines, so don't f it up.
The 10mm bolts on the snout and rear gear case come off self explanitory, you dont need to drain the gear case if you do it right.
I have had bunches of them apart, you have to be real careful and make sure everything goes back the same.
Old 05-10-2012, 12:20 PM
Greg Good's Avatar
Yeah, I marked the gears so they will go back correctly.
I did a google search last night on eaton blowers. I found a youtube that a Chevy engineer made showing the internals of the blower. I'm making a puller right now to get the input shaft out.
Then I can put the manifold/head combo on the flow bench and see how much it drops the head. These LS9 heads aren't very good. The port I flowed was 294 cfm, which is 23 cfm down from a typical stock LS3 (317).
Thanks for the info. It's appreciated.
Old 05-11-2012, 07:15 AM
veee8's Avatar
Yeah the swirl wings in there defiantely hurt overall flow.
Old 05-11-2012, 08:40 PM
Greg Good's Avatar
I got my puller made and the hub off. Rotors slid out the back.
Bolted the manifold onto the head, and got 270.
I mis-typed in the earlier post. The stock intake port flowed 291. Manifold hurt it 21 cfm. Now am going to put the manifold on a ported intake port to see how bad it hurts flow on a ported head.
