09 5.3 and f-body pan wont fit
Old 06-28-2012, 07:12 AM
z2fast8's Avatar
Default 09 5.3 and f-body pan wont fit
swapping a f-body pan out on the truck so we can lower the motor down in the chassis for the bodydrop. long story just trying to get the motor as low as possible so the truck can set on the ground. anyways the camaro oil pickup hangs down and hits the pan. why?
Old 06-28-2012, 09:32 AM
KCS
Moderator
KCS's Avatar
Bend it up. Should have 1/4"-3/8" clearance between the pickup and pan. If not, you can usually "manipulate" the pickup with a soft mallet.
Old 06-28-2012, 10:00 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
The easiest solution might be to get the correct pick-up tube for the F-body pan. The trucks and F-bodies use different pans, windage trays, and pick-up tubes that all need to jive together!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
The following users liked this post:
Jimbo1367 (05-12-2021)
Old 06-28-2012, 10:49 AM
z2fast8's Avatar
we did get the f-body pickup and windage tray. the pan hits the tube at the bend after the oil pump
Old 06-28-2012, 08:45 PM
S10xGN's Avatar
If the parts you got are correct, then maybe the pickup tube isn't seated all the way in the pump? Does the bolt hole on the pickup tube line up correctly with the main stud?
Old 06-28-2012, 10:42 PM
Closed ex-Sponsor Account
SteveDoten@ARH's Avatar
sounds like the parts guy screwed up; I've never seen a pn on a p/u tube; compare the tube to a Fbod tube
I C5 tube uses the opposite hole in the pump for attachment; not sure if the Fbod is unique in the dozens(guessing here) tubes avail for the LS motors
I'm guessing the oil pump isn't shimmed for a x2 roller chain?
Old 05-11-2021, 04:17 AM
CarbedLm7e46's Avatar
bro im having same exact issue rn. What ever came of this what was the problem. Very interested
Old 05-11-2021, 08:19 AM
Received 3,039 Likes on 2,366 Posts
z2fast8 hasn't been here in 7 years. You might watch post dates from now on....
Old 05-11-2021, 05:39 PM
All u have to comment is some dumbass comment. I was looking for help idc what date he posted it. Ur a ******* douche. Tell ur mother i say hey
Old 05-11-2021, 05:48 PM
01CamaroSSTx's Avatar
Received 1,804 Likes on 1,305 Posts
See post #2
G Atsma (05-11-2021)
Old 05-11-2021, 09:14 PM
Received 3,395 Likes on 2,098 Posts
Take it easy on old Gary. He’s managed 15k posts telling guys this stuff...
Old 05-11-2021, 10:09 PM
bro
I'm having same exact issue . What ever came of this what was the problem. Very interested
You asked what ever came of this. The only one who can answer that hasn't been here, AS I SAID, DOUCHE!!
NOW WHO'S BEING A DICK???
The following 2 users liked this post by G Atsma:
dixiebandit69 (05-20-2021), Jimbo1367 (05-12-2021)
Quick Reply: 09 5.3 and f-body pan wont fit
