the best heads for a 440
Old 08-27-2012, 11:42 PM
bugy's Avatar
Question the best heads for a 440
i'm considering these two pair of heads for my 440, LS7 ported ones, or a TFS 225's cnc ported with cathedral ports, what do you think?
Old 08-28-2012, 01:50 AM
lilaaron233333's Avatar
LS3/L92 heads I would say. They flow pretty good and flow even better when ported.
Old 08-28-2012, 07:26 AM
raymond mckinney's Avatar
I would go with some nice ported Ls7's or Tfs 245's. 440 cubes is a big motor and deserves a nice cylinder head.
Old 08-28-2012, 08:21 AM
SHovV's Avatar
Port some 243's and never look back.
Old 08-28-2012, 04:04 PM
gnx7's Avatar
The TFS heads will make 20-40rwtq more in the lower/mid RPM's vs. ported LS7's where around 6K RPM the LS7's will begin to shine. The difference up top isn't a ton better on the LS7's compared to how much the TFS heads beat them in the low/mid range. LS7's up top will only make around 10-15rwhp more. Torque is about the same.
In the end they will end up costing about the same. I say TFS heads.
Don't have any bends in the air intake inlet.... meaning no 90* bends. That will suck up 20rwhp+
Old 08-29-2012, 08:45 PM
LS1TECH & Trucks Sponsor
Sales4@Texas-Speed's Avatar
I would definitely recommend the PRC aftermarket casting 285 LS7 heads for this sized motor. They will easily make some of the most power out of any head available for this type of setup.
Old 09-04-2012, 10:00 AM
bugy's Avatar
having in mind the car is kinda light weight car...
Old 09-04-2012, 10:22 AM
FlamingTA's Avatar
TFS 225 will be too small. You might want to look at some AFR 245's also.
Old 09-04-2012, 11:13 AM
6D9 Matt's Avatar
Another vote for TFS 245's.
Old 09-05-2012, 08:39 PM
gouldy's Avatar
Try Googling both heads and look at the results for each.
Make your discission based on your research and proven results like dyno figures and track times and not on someone's personal opinion or vested interest. There are a number of great brands out there at present so have an open mind when you do your research.
If you can find results that have been duplicated on a number of different builds there is a good chance it will work for you as well.
Being a ginea pig for unproven productis can be very costly if they don't meet your expectations however if they do work your build will be the one that will set the bar and make others wish that they had taken a gamble as well.
Good luck
Old 09-06-2012, 05:40 AM
KILLERARMY's Avatar
A set of All Pro Cylinder Heads from WCCH would be a nice choice.
Old 09-06-2012, 07:30 AM
ramairws6's Avatar
^^^This^^^
Old 09-06-2012, 08:16 AM
Sales@Tick's Avatar
Trick Flow 245's or even 265's.
You cannot beat a 245cc cathedral port head that flows 355-360cfm on the intake and over 290cfm on the exhaust with a pipe(would you ever run your cylinder heads without headers?)
I saw a flow chart for a set of worked over TFS 265's the other week that hit 401cfm on the intake and well over 300cfm on the exhaust. You will never find a LS3 or LS7 head that can attain the I/E% a TFS cathedral port can(or any cathedral port for that matter).
All out intake flow isn't the end all be all you have to get it out the exhaust also. A well balanced head with port velocity and a long intake runner manifold can make some serious power for a 440 cubic inch motor.
Old 09-06-2012, 06:15 PM
bugy's Avatar
Thumbs up
Good luck
that's a good point googling and searching dyno test results, thanks
thank everybody for replying, every advice is considered before making the choose.
Old 09-07-2012, 03:35 AM
02sslayer's Avatar
I'm gonna go with AFR 245s when I build my 440 unless I decide on the 402. We will see
Old 09-10-2012, 07:47 PM
Z06_Fan's Avatar
How would a nice set of MAST 275 cathedral heads fair on an engine like this?
Old 09-10-2012, 08:27 PM
durrettcustoms's Avatar
Mast 275s are a great choice or their Ls7 305 Heads.....with 2.250" intake and 1.600" exhaust valves!
Old 09-10-2012, 08:31 PM
UGotBeaT's Avatar
what size valves on the tfs 265s?
Old 09-10-2012, 08:48 PM
blackonblacksls's Avatar
I think I have seen more square port heads over 140mph NA in the quarter than anything else. Ls7 especially.
Old 09-10-2012, 08:49 PM
Lots of bad cath port motors going mid to high 130s. Lots of bad ls7 motors going 140+
Quick Reply: the best heads for a 440
