My cam only l92 build....475rwhp?
Old 09-26-2012, 07:38 PM
csilvers1984's Avatar
Default My cam only l92 build....475rwhp?
Recently sold my TFS headed 404 ls2 to build a simple cam only street motor. What do you think?
09 l92 short block 56k
Stock heads milled .047
Stock pistons Flycut on intake side .070-.075
LS9 head gaskets
LS3 intake,90mm TB and 42lb injectors
eBay head studs(if they don't break when torqued then I'm alright)
Cam/spring kit from Brian Tooley Racing
234/248 .612"/.595" 112+4
T56 with RXT twin
1 7/8 longtubes
Hoping for 475rwhp and 10.50s at 130+ in a 4.08 geared 89 Nissan 240sx
Old 09-26-2012, 07:54 PM
Sales@Tick's Avatar
Should make good power with that cam maybe not 475, but close. Did Brian do that cam? Looks like LXL intake and Extreme RPM exhaust.
We had a 2010 in here the other day that made 507/440 with AI chamber work on the 821's and a 231/238 .617/.615 113+2 camshaft and a fast 102.
Old 09-26-2012, 08:14 PM
Brian didn't spec the cam just had it laying around actually. I was going "budget" this time around but I'd spend a little more if a custom grind would net more hp.
Old 09-26-2012, 08:41 PM
Sales@Tick's Avatar
Oh ok, it looked like a lobe combination he would of used.
I like it though. Budget can make great power.
Old 09-26-2012, 09:12 PM
Thanks! I did turn to Brian for advice on my last build an this one also. He thinks the cam will work well for my intended use. Great knowledge right up the road from me haha.
Old 09-26-2012, 09:27 PM
Sales@Tick's Avatar
As do I think it will work well too.
They say great minds think alike.
Good luck.
Old 09-27-2012, 02:22 AM
bww3588's Avatar
I don't think you will have a problem hitting your goal. I have a 370 almost setup exactly like yours with a tad smaller EPS cam. Geoff seems confident in me hitting 475+ at the wheels.
Old 09-30-2012, 07:48 PM
Picked up my cam and platinum spring kit from Brian Tooley Racing this weekend. Also got the l92 heads back from machine shop. Ended up getting them milled .047 for around 11.9 compression. I'm still debating on using ls3 or ls9 head gaskets.....any opinions?
Old 09-30-2012, 10:13 PM
1989GTA's Avatar
I bet you make your goal.
Old 10-01-2012, 07:27 AM
Sales@Tick's Avatar
That's going to really help wake that thing up with the compression you chose. I like it, you are fly cutting right?
Old 10-01-2012, 07:40 AM
87silverbullet's Avatar
L92 already has valve reliefs, whether he needs to cut them deeper, I don't know.
Old 10-01-2012, 08:29 AM
My friend has a l92 with .042 milled heads and his cam is almost identical. I will have to confirm the CC on the l92 valve reliefs.
Old 10-01-2012, 02:49 PM
Sales@Tick's Avatar
That's good to know then.
Old 10-03-2012, 09:27 PM
Picked up my heads from the machine shop and 6 exhaust and 1 intake valves are bent! These budget heads are up to $370 after milling,valves faced,seats worked and 7 new valves...on a good note I picked up my ls9 head gaskets,ls7 timing chain and ls7 cam gear.
Old 10-04-2012, 07:13 AM
Sales@Tick's Avatar
Ahhh the joys of owning a modified vehicle.....
Old 10-04-2012, 04:28 PM
Today I ordered 7 new valves from GM for $128. I was hoping to assemble my longblock this weekend but I'm going to cut valve reliefs on the intake side first. My buddy recently blew a head gasket on his setup which is very similar and had PTV contact on the intake side. His cam is almost identical to mine and his heads are milled .042 compared to my .047. Here's a pic of his motor while changing head gaskets,you can faintly see where the PTV contact was.
Old 10-05-2012, 11:31 AM
adamantium's Avatar
In for this build
Old 10-06-2012, 11:12 AM
LSxPwrDZ's Avatar
Yes it should be noted that the L92 has reliefs... BUT only on the exhuast side for the VVT to retard the cam. Retarding the cam creates PTV issues with exhaust and advancing creates more with the intake. They don't advance the cams in those VVT motors much from dot to dot, something like 7-10* depending on which VVT motor you have, however the camshaft can retard up to around 40+* on some setups creating PTV issues with the exhaust valve on stock VVT engines. The good thing is the piston is plenty thick enough to cut some nice .050-.075" eyebrows in them to gain plenty of PTV!
Silvers you know what I think... Should make some killer power.
Old 10-06-2012, 08:04 PM
As my tuner I'm sure you will get everything out of it....but will it MPH? Only track times will tell! If not we'll put some cathedral ports on it hahaha
On to the build...today I notched my pistons .075ish on the intake side and lapped all my valves. Tommarow I will do a final cleaning and hopefully assemble the long block. Heres a quick pic of the new intake valve reliefs.
Old 10-08-2012, 11:51 AM
cam
cam's Avatar
In for results. Nice work with the Vette btw
Quick Reply: My cam only l92 build....475rwhp?
