Clevite P Bearing Spec Tight?
The machine shop checked all my bearing clearances for me and came up with:
Mains: 0.0011in (Clevite P spec 0.0002-0.0018)
Rods: 0.0021in (Clevite P spec 0.0012-0.0037)
Both are about in the middle of the Clevite specifications, but the Clevite spec for the mains sure seems tight by performance standards. Do people actually follow the Clevite recommended clearances?
The engine is an LY6 iron block, L92 heads, stock crank, compstar rods, wiseco pistons, 10.25:1 compression, 227/235 .614/.621 113LSA, full length headers, and LS3 intake going into '70 Nova for primarily street and some autocross use. The mains are studded and were line honed. I do not plan to run nitrous or boost.
Do you think these clearances are ok for this combo?
LS1Tech Premium Sponsor
I wouldn't have much of any issue with that rod clearance, but the mains I'd likely go with an X bearing to get closer to .0021" or so (assuming you don't want to have journals polished or any machining on block to loosen it up).
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
As was said, use X bearings to open up the main clearance to .0016"-.002" - but I never go more than that on an aluminum block unless it's a drag race application. You can mix shells in STD and X in order to split the difference.
Your machine shop should not try to polish more than .0002" out of a crank journal to gain clearance, it will always cut more out of the middle due to the nature of the belts.
.002" on the rods is fine.
I read that you are a machinist. Why don't you do your own work?
If you're talking about me, I do some hobby machining and have a Bridgeport-style mill in my garage, but engine machine work is beyond my capabilities (both skill and equipment).
UPDATE
I ordered a set of MS-2199HX (add 0.001 clearance) main bearings. The machine shop measured the new clearances. Here are the before/after clearances (P vs. HX)
#: P/HX
1: .0015/.0026
2: .0010/.0024
3: .0010/.0025
4: .0012/.0025
5: .0011/.0026
From what I've been reading, the new clearances are spot on. I plan to measure them myself also to confirm.
UPDATE
#: P/HX
1: .0015/.0026
2: .0010/.0024
3: .0010/.0025
4: .0012/.0025
5: .0011/.0026
I'm sorry, I was referring to this quote. I should have been more specific. I had read in a different thread, that bww mentioned he was a machinist. I thought it was odd that he'd got his engine back from a machine shop, when he said he was a machinist.
Those look good to me!
__________________
UPDATE
#: P/HX
1: .0015/.0026
2: .0010/.0024
3: .0010/.0025
4: .0012/.0025
5: .0011/.0026
UPDATE
#: P/HX
1: .0015/.0026
2: .0010/.0024
3: .0010/.0025
4: .0012/.0025
5: .0011/.0026
Yes Clint, those clearances look great. Sorry about the hi-jack.
