11-22-2012, 06:40 PM
#1 TECH Junkie
2009 Pontiac G8 My Garage
12,xxx Miles, Change Valve Springs? Currently have around 12,500 miles on my G8 with PRC springs and a 223/231 cam, modifications in my signature. At what point should these springs be changed?
Happy Thanksgiving
__________________
2000 Maple Red Metallic Trans Am A4, Grandfather Left It To Me
LME 440 LS7|TSP PRC LXR 285cc LS7x|278/286 .718 .702 112+4|Becks Intake 115mm|Direct Port|D&D T56 Mag|McLeod RXT
2009.5 Pontiac G8 GT SMR ||KOOKs 1-7/8"|Corsa|VaraRam|223/231 .610/.617 115+4|3.45s|Coan 3400||All Tuned by HT at REDLINE
11-22-2012, 09:44 PM
#2 TECH Senior Member
Garage is empty, add now
Have them checked. Lots of factors at play and having them tested is the only way to be certain.
11-23-2012, 12:01 AM
#3 TECH Junkie
Quote:
Originally Posted by
Tainted Have them checked. Lots of factors at play and having them tested is the only way to be certain.
Checked, meaning send them to a machine shop?
__________________
11-23-2012, 12:09 AM
#4 10 Second Club
2011 Chevrolet Camaro
I'd change em. New springs only around $100. Opinions vary but 1yr/12k is a personal rule of mine for springs with aggressive cams.
__________________
2011 RJT 1SS -
430CI ,
Jake's 4L80 , Circle D, 3.91, E85,
33xx pounds
1998 T/A (Wife's) - LQ4 + 799s + Cam + LT + Circle D
11-23-2012, 12:11 AM
#5 TECH Junkie
DietCoke I'd change em. New springs only around $100. Opinions vary but 1yr/12k is a personal rule of mine for springs with aggressive cams.
Good point. I forgot what I spent at Texas speed. But if I am going to pull the springs to check them. For 100$ I'll just replace them.
Thanks for the fast responses!
__________________
11-23-2012, 12:18 AM
#6 10 Second Club
The kits are expensive (Seats, retainers), but the springs alone are very cheap.
__________________
2011 RJT 1SS -
430CI ,
33xx pounds
11-23-2012, 08:06 AM
#7 TECH Junkie
I'd call Brian Tooley@BTR he has some very good prices and they are always in stock.
__________________
11-23-2012, 08:32 AM
#8 12 Second Club
2001 Pontiac Trans Am
87silverbullet I'd call Brian Tooley@BTR he has some very good prices and they are always in stock.
+1 good springs and Colorado speed has them 10% off this weekend with free shipping. Just FYI.
__________________ 01 Ws6,m6, ASC#618 of 1583,AES built forged 416,ArP'd,Morels,LPE Ls3 heads 12-1 comp,FAST 102 by chris1313,N/W 102 Tb,Racetronix F/P,65lb inj,C5r T/C, LsR 243/259 .624 114+3,P/B 10% Ud,Kooks 2" headers,Kooks yp,Dmh dual c/o's,COMPLETE UMI suspension,SLP Torque arm,viperized T56 by wrencher,Textrellia,Moser 9" spooled w/4.11's & 35 spline axles, Koni 4th Gen's,BMR springs,Sjm abs delete,magna flow CB, 542hp/525tq StraightLine Tuned!
11-23-2012, 12:49 PM
#9 TECH Junkie
I'll be doing these springs with the PRC seats, and retainers.
http://www.coloradospeed.com/manley-...s-p-10431.html
NexTek are some nice springs...
__________________
#10 TECH Junkie
Thank you for the help!
__________________
LS1Tech
Pontiac Firebird
Paid Advertisement
Tags 2005 , cost , gto , ls3 , lsx , milkes , mioes , replace , replacing , springs , valve , valvesprings , xxx , xxxlsx , xxxmioes
Thread Tools Search this Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
