Swapping from ls1 to ls2 platform
Swapping from ls1 to ls2 platform. What do I need to do so all the wiring works. I have a early ls2 so I think I just need to lengthen the wires for the black cam sensor. Not sure about the rest. [O4 GTO wiring and pcm]
Thanks Randall
Thanks Randall
Use the ls1 knock sensors and drill and tap the block for them to fit.The ls2 sensor don't work well with the ls1 computer.Go to ls1gto.com and do a search and you'll get some good info it.
I did find this
http://www.wikiauto.com/Pontiac-GTO-...2-Install.ashx
same thing here
http://www.ls2.com/forums/showthread.php?t=626014
same thing here
AFR 230 heads and I already have the ls2 cam gear cloyes hex adjust. Its a 402 with callies crank and 24 reluctor wheel. Did U have to do any thing with tuning on knock sensors? R U using LS1 or LS2 knock sensors? What harness are U using?
Here is the thread! Allota the info was problem already in the above links.
http://www.ls1gto.com/forums/showthread.php?t=451843
