iron 6.0 cam suggestion
Old 05-07-2013, 10:56 AM
matt k's Avatar
Default iron 6.0 cam suggestion
hi new here, but not new to motors or cars. had an 01 trans am new with bolt ons and nitrous then, but not a lot of parts available back then, anyway 2 kids and years later iam back into cars and building a few different cars with my dad. iam looking for a cam suggestion or someone who does custom cams. it will be a daily driver, 70 nova, 5sp, 3:70 or 3:90 gear. 6.0 with stock crank, aftermarket rods, l92 heads, duel plane with carb setup. i would like it to be street friendly, idle good, good vacume, yet have just a little lope at idle. iam not really conserned with peak numbers, iam looking for a flat tq and hp numbers through out the curve, and want to keep the numbers around 6000 rpm or under. thanks for the help and i hope i posted in the right spot. and compression will be around 10:1
Old 05-07-2013, 06:32 PM
matt k's Avatar
Also should I stick with the cathedral port heads instead of the l92 since its a street motor and with a cam under .600 lift?
Old 05-08-2013, 07:21 AM
Fastdriver1992's Avatar
I used to run a crane cam 228/232 .551/.551 112lsa. Great cam made power throughout the rpm range. I believe the power range was 2500-6200rpms. Its a great street cam. I dont have the part # but if u want to call crane with the specs i'm sure they can find it for you
Old 05-09-2013, 06:22 PM
matt k's Avatar
well going with a stroker 408, cathedral port heads, dual plane intake, carb. martin@tick suggested 239/246 .624/.595 113. kinda scared me how big at first compared to what others suggested but i ordered after talking with him. hope it has good street maners.
Old 05-16-2013, 09:34 AM
matt k's Avatar
what do you guys think?
Old 05-16-2013, 10:16 AM
lsx2000z28's Avatar
I'm always for max effort cams. I use to own in my stock bottom end , no fly cut ls1 a mti s1 (244/244 612/612 112 lsa) now I have a custom ground eps cam(23x/24x 64x / 61x 109+3) and drive ability is amazing on both all in the tune. I'm goin to build a streetable 418 on e85 or pump gas with a huge cam. Plus 200-250 shot on top.
Just my 2 cents
Dustin
Old 05-16-2013, 01:34 PM
MASS seller approved
low2001gmc's Avatar
martin at tick can be trusted and the above cam is not really big at all for a stroker. actually seems like pretty nice cam to run. well help to at least port exhausts on heads for optimum performance.
Old 05-16-2013, 02:41 PM
matt k's Avatar
thanks for the confidence, i guess the numbers surprised me a bit since iam use to older small block chevy stuff.
Quick Reply: iron 6.0 cam suggestion
