Should I mill these heads?
Old 08-26-2013, 11:49 AM
COSTIGAN86's Avatar
Default Should I mill these heads?
I have a set of ported 799s going onto my LS2 with a ASA cam. Should I mill these heads first? I do not want ptv clearance issues. Cam is .525/.525 226/236. Milling .025 will bring it down to right around 61cc, bringing the CR up to almost 11.5. What would you do?
Old 08-26-2013, 01:36 PM
slt200mph's Avatar
High compression is free HP. I'd mill them. I have a set of heads milled down to a 11.4 to 1 ratio. Been running them for 5 years now.
Old 08-26-2013, 01:40 PM
slt200mph's Avatar
High compression is free HP. I'd mill them. I have a set of heads milled down to a 11.4 to 1 ratio. Been running them for 5 years now. Nuff said..
Old 08-26-2013, 02:54 PM
KT2
KT2's Avatar
Old 08-27-2013, 05:05 AM
COSTIGAN86's Avatar
anybody else?
Old 08-28-2013, 03:12 PM
COSTIGAN86's Avatar
I cc'd the chambers today and they are 67cc after the port work. At .006" = 1cc, shaving .030" will bring the chambers to 62cc, giving me 11.26 compression. Anyone see any piston-to-valve clearance issues with this?
Old 08-28-2013, 03:13 PM
COSTIGAN86's Avatar
I'm using stock MLS head gaskets, .051" compressed
Old 08-28-2013, 03:22 PM
yonerhottlt1's Avatar
With a cam that small, I don't see you having any PTV clearance issues at all. Although it's always best to just measure to be sure
Old 08-28-2013, 06:08 PM
COSTIGAN86's Avatar
I know that its best to measure, but was hoping to find someone with the same or similar setup and if they had to flycut.
Old 08-28-2013, 07:32 PM
fst100's Avatar
i thought 243/799 heads were 64cc not 67cc which were 853/241s?
Old 08-28-2013, 09:19 PM
COSTIGAN86's Avatar
^ you are correct. After polishing the combustion chambers they are 67cc.
Old 08-28-2013, 10:20 PM
fst100's Avatar
so you have either 241 or 853s then?
Old 08-28-2013, 10:40 PM
427zm's Avatar
Something to thing about; if you went to the .040 Cometic gasket, you could mill less and still get the same added compression you desire. The other thing this will do is add quench which helps protect against detonation. Tight quench is a great thing for a NA motor. Oh, and as for your original question, I don't think you'll have PtV issues at all with that cam. Intake duration is typically the main thing to concern yourself with. Now, the only way to make sure is to measure.
No, what he's saying is that the back cutting of the valves, and port work increased the chamber size.
Old 09-09-2013, 12:04 PM
COSTIGAN86's Avatar
Update: I measured and had plenty of clearance. Milled .020" and still have over .100"
Old 09-09-2013, 02:19 PM
fst100's Avatar
Red face
ah ok. so it brought the cc from 64cc to 67cc and now that he milled the heads 0.020" they're now around 63.75cc-ish?
i'm still new to all of the heads and such. so porting the innards of the heads also affect the cc overall, meaning for example 799 heads be 64cc and if i do a home-port job such as removing the lump and bulleting the intake valve area that the overall cc would go up some? sorry for the threadjack btw COSTIGAN86
Old 09-09-2013, 06:26 PM
KCS
Moderator
KCS's Avatar
The ports and chambers are two different things. Narrowing the guide boss and removing the rocker boss will increase the volume of the port, and will have no effect on the chamber.
Old 10-08-2013, 07:34 PM
mgood613's Avatar
I am running the howards vs ASA cam with PRC 243/799 Stage 1 heads Milled .030 with .045 cometic gaskets on a LS1.
My PTV was .083 intake and .125 Exhaust
Just FYI, but I would always check.
Quick Reply: Should I mill these heads?
