questions about choice/Cam swap on 2010 LY6 with 100,000 miles.... Replace lifters?
Old 09-02-2013, 08:59 PM
WRXINTX's Avatar
Default questions about choice/Cam swap on 2010 LY6 with 100,000 miles.... Replace lifters?
Hello all,
I don't know the previous history of the engine, only that it was in a plain-jane 2500 regular cab truck.... being a 2010 with 100,000 miles, they were mostly highway miles I think..
I am going to do a cam swap to make sure I have plenty of power out of this engine.... as I have driven a stock 2500 truck with this type of engine and I wasn't overly impressed with the top end or torque for that matter, of course, it was a long bed, quad cab, and very heavy ....
I have two VVT cams, one with 210/218 @.050 and .499/.499 lift
or
a Mast VVT-1 with the 220/234 @ .050 and .570/.588
This is going in a 5,000 lb LY6/4L80E / 4.11 gears/ 33-35 inch tires- 4X4 swapped truck with a 2,200 stall PTC converter....
I am looking for maximum power and mileage out of the cam, the best of both worlds.... thus, the reason I am staying VVT.....
hate to come off as a newb, but, I am not used to these VVT cams and camming a VVT engine for a heavy truck..... All I know is that I don't want to be dissappointed at the gas pump or when I put the skinny pedal down....
I am just as afraid of doing all the work and being dissappointed with the cam being either too small or too large. I have been trying to get feedback on the MAST VVT-1 cam users with trucks and see what kind of mileage people are reporting compared to the stock cams....
Also, I am wondering if I should replace these lifters while I am into the engine or just do the cam swap and leave the stock lifters in place?
Old 09-08-2013, 10:42 AM
Jimbo1367's Avatar
Try a SEARCH using "Patrick G" He has spec'd a custom VVT cam with success before. Obviously he specs the proper springs and might have insight on lifters. At least replace them with new replacement lifters.
Old 01-07-2019, 11:03 PM
best stop's Avatar
Default Do I need to change lifers?
I just bought a ly6 complete engine with 30,000 miles. My plan is to install it in my 2006 pontaic gto with a built t56 trans. I want to install headers without cats back, loopy cam that makes power on the big end. Now deleting the vvt do I need to change the lifters? I've been messaging the guys from texas speed and they say no all I need is
58x adapter https://www.texas-speed.com/p-4734-lingenfelter-58x-24x-crank-sensor-trigger-conversion-module-58x-24x-reluctor-wheel-conversion-module.aspx
Vvt delete https://www.texas-speed.com/p-724-vvt-delete-kit.aspx
Cam kit Bald eagle cam https://www.texas-speed.com/p-249-texas-speed-dual-spring-cam-package-for-rectangular-port-heads-ls3l92lsal76.aspx
Gm ls3 manifold https://www.texas-speed.com/p-4476-gm-ls3-intake-manifold-assembly.aspx
Old 01-07-2019, 11:33 PM
Received 3,022 Likes on 2,353 Posts
VVT you only change the cam sprocket, front cover, and the sensor itself, along with a wiring extension.
AFM/DOD you change the lifters, lifter trays, pushrods, and valley cover. Plus cam if desired.
Old 01-07-2019, 11:42 PM
best stop's Avatar
thank you for the info. I'm glad the guys at texas speed were right then. Im gunna start buying parts. Anything else you recall I would need to get close to 500 hp
Old 01-07-2019, 11:43 PM
best stop's Avatar
Is there a better intake then a stock ls3? That's cam kit from texas speed?
Old 02-05-2021, 08:08 AM
Smile_E_Face's Avatar
Default Results?
OP. What did you end up installing? I've got an L96 and I'm looking to do the same.
Old 02-05-2021, 11:28 AM
Both the LS3 and Gen IV rectangular head truck intakes are excellent units. They both are good for 600 HP and dyno the same numbers.
Quick Reply: questions about choice/Cam swap on 2010 LY6 with 100,000 miles.... Replace lifters?
