Which block for boost?
Old 11-05-2013, 10:16 PM
6togo's Avatar
Default Which block for boost?
Thinking of doing a twin build again and think that a stock LS 2-3-7 block with forged internals will work without getting crazy with the big dollar 6 bolt blocks. I would like over 400CI with twin 67's making around 800-1000rwhp and i would like to use a aluminum block to keep the weight down is these feasible? and tuned properly will it last? It will be a weekend'r so not allot of mileage and probably keep the boost turned down most of the time on the street but for those 4-5 times a years i hit the 1/4!
Old 11-06-2013, 11:04 AM
87silverbullet's Avatar
You can count the LS7 block out unless you plan on resleeving it. The walls are prone to cracking compared to other stock blocks. With an LS2 or 3 block you will have to stroke it to get above 400 cubes which brings me to that you don't need 400+ cubes to make 800-1000 rwhp. A stock cube forged LS3 will do that.
Old 11-06-2013, 06:45 PM
6togo's Avatar
I understand that but i'm starting from scratch it will cost the same why not get the extra CI that way it will make the power even easier!
Old 11-07-2013, 08:26 AM
koolrayz's Avatar
a 4" crank in a stock block will have reliability issues due to the short sleeves in a stock block. If you are hell bent on the extra cubes then get the stock block sleeved you will have a much happier system. even a dry sleeve setup will help the longivity.
I would recomend given your goals that you stick with the stock stroke.
Old 11-07-2013, 11:56 PM
TurboAv's Avatar
What he said ^^^^^^^.
If you are going turbo I don't really see the point of a stroker crank in a factory block. If you go with an ERL, RHS, DART, sleeved stock block, then stroke away.
Old 11-09-2013, 02:53 PM
214Chevelle's Avatar
I echo both of these guys statements. Besides, is there a such thing as a cheap, twin turbo build. I'm only asking cuz you said "not going crazy with big dollar 6 bolt blocks." But, a properly done GM block with the right forged internals will still cost a pretty penny. Like 87silverbullet said, the stock LS7 is a no-go as the walls will crack. Cylinder wall #7 is very common. I have one sitting on my garage floor waiting to be sent to ERL in the future when I decide to start building my 68 C10 swb. And to answer my own question, yes, there is a cheap way of doing things. But, I promise you will regret it. Ask me how I know. LOL!!
Old 11-23-2013, 08:34 AM
Troy's Notchback VW's Avatar
Stick with the LS3 block without stroking it. No need to bore the block. keep all the material you can. They are pretty strong.
Quick Reply: Which block for boost?
