H/c/I vs. cam only benefits
Ok, the decision has been made to stay NA.....my 05 mn6 vette is at full bolton status now.....my question is, what are the benefits to going with aftermarket heads (tfs225) and a custom cam vs. Custom Cam only? I mean on a street driven car, would the heads make that much of a difference to justify the cost?
As someone else mentioned, the benefit is that you can run a much smaller cam (for driveability and efficiency) and at the same time make the same kind of power as just a big cam only.
With my heads and baby cam I am making the same kinda power as people with a big cam only. Except that I have significantly more power down low and it's easier to drive and get better mileage.
One of the mods...JayplaySS2 has a C6 with stock short block, TFS 220 heads, and a decent sized cam which dynos over 500 rwhp. I can't find his thread right now but to answer your question...YES heads will help alot !!!
https://ls1tech.com/forums/generatio...inally-c6.html
In short, yes heads are well worth the cost when paired with a nice cam and full bolt ons. I took a similar path -- cam + full bolt ons and then added the heads & fast 92 at the same time. I went with budget heads to save cash for a N2O setup and even the budget PRC heads amounted to huge gains across the powerband.
If you're still running street radials, your next mod decision will likely be tire related.
I have been following "jays" build,very impressive! I am running a pretty sticky tire now at 400rwhp and can be tough to stick w/o some hot street/tires. plan to run R888's next go around as handling is of great importance to me being on coilovers now.
We use the TEA TFS "As Cast" 220cc heads on 4" stroker motors all the time! They work great!
500/500 many times with those heads and a good camshaft to match.
They're very well priced and have the capability to be "opened up" by your porter of choice at a later date if you wished.
