LS7 head spring pocket diameter
Old 09-21-2014, 08:46 PM
kllrvet's Avatar
Default LS7 head spring pocket diameter
I need to upgrade my valve springs, and I have a set that are 1.375 OD. I have understood the spring pocket diameter is 1.300. I just wanted to see if anyone knew for sure.
Thanks
Tony
Old 09-21-2014, 10:46 PM
lil john's Avatar
I got you I'm on xbox live and watching NFL highlights will return give me a second. If you go to PAC springs look up there biggest LS spring. Check and see what you got.
Aka LSX RACING: Forza 4&5 Master
Also a 8yr ole LSX tattoo also.
Old 09-21-2014, 11:08 PM
lil john's Avatar
Factory Ls7 heads can go up to 1.55 by my records. Its on writen file I didn't want 2 stop racing.
Old 09-22-2014, 09:12 AM
KCS
Moderator
KCS's Avatar
No, that is not correct unless you do some trick **** with the spring pockets. Stock is around 1.30", so a 1.375" probably won't fit or might even have an interference fit.
Old 09-22-2014, 12:09 PM
lil john's Avatar
Good looking out KCS. I just knew my partner Grant used some big springs and had it written down. I assume the heads are off, so spring pocket machining vs new springs. As the old NFL motto went you make the call. lol...
Quick Reply: LS7 head spring pocket diameter
