LS3 All Motor Dyno Results
09 G8 GXP, 6Manual
Chad Barton Spec - Comp Cam 233/246/.618/.615 113 LSA +0, LSL/LXL
Texas Speed PRC aftermarket LS3 250CC heads, 62cc chambers, hollow-stem intake valves
Approx 11.5:1 Compression
Tony Mamo Ported FAST 102
NW 102 TB
Dave Steck E85 Flex Fuel Conversion, Dave Steck Tune
LS9 Injectors
Deatschwerks DW300 (340LPH) Ethanol Capable Pump
Squash Performance C5 Returnless PTFE/Teflon Fuel System
ARH 1 7/8" Long Tube Headers, Catless Midpipe, Solo Axle Back
Mesiere Electric Water Pump
ATI Balancer, not underdriven
Stock 2-Piece Driveshaft, Rubber Giubos
GForce1320 750hp Axles
Camaro SS 1LE 3.91's w/Eaton TrueTrac Diff
Chad Barton Built
On E85, 70% actual alcohol content:
Not the magic 500rwhp I was shooting for, but very healthy and I'm satisfied. Overall very happy with my result. Hopefully this data is useful for someone else for comparison purposes.
NW 102 TB
LS9 Injectors
Chad Barton Built
I agree, those are good numbers. Interesting that the peak hp point does not change to much with the long runner intake manifold. The camshaft moves it around a little but not to much.
Dan,
Nice results....good torque # but I would have expected to carry a little better.....that's why the magic 500 number slipped your grasp. You made enough peak torque to easily get there if the engine didn't roll over so quickly (something is preventing it from effectively filling the cylinders at higher RPM).
On paper looking over the cast of characters, IMO it should have peaked 2-300 RPM's later (HP) and if it did you would have nailed the 500 mark for sure.
Numerous things could effect this.....for now enjoy what you have and if down the road your up for excavating and finding some of that power that eluded you now look me up in the future.
480+/450+ is a fun driver and the power comes in early so Im sure the car feels great.
Cheers,
Tony
Cheers,
Tony
Thanks Tony for your help with this project and thanks for the analysis.
The throttle response is explosive in this car, even at low engine speeds. It's almost frightening how hard it pulls and keeps pulling, but this is my first car this powerful.
I agree, something happens at 5500 and it kind of loses steam.
Chad Barton and Dave Steck have a plan of attack to get me to my goal. We are thinking there is an airflow restriction and/or that we can add additional timing. The tune is on the conservative side at this time.
I wonder if your valvetrain is starting to get unstable beyond 5500?
What valve springs are you using and have you considered stepping up to 11/32 or 3/8 pushrods?
Thanks for the idea. I'm running dual springs (BTR?) and regular 5/16 hardened pushrods. Chad sez he'd expect unstable valvetrain to show really jumpy on the dyno.
Hmm would've expected some better numbers out of that setup, and I agree it doesn't seem to be carrying past peak too well.
Those numbers are achievable by a stock headed stock intake LS3 (well maybe not the torque). With a ported FAST and aftermarket Trickflows I thought it would carry the power better.
I would look at some 3/8" Trend pushrods. They clear the heads without having to modify the holes and they don't break the bank.
Those 5/16" are probably flexing enough to cause that plateau up top.
You've got quite the list of goodies in your OP that should be freeing up some more power. I'm not too familiar with E85 tunes/setups for the G, but I do know that full top end builds on the L76 with a matching cam will net around 430 on pump gas. An LS3 build with all the aftermarket goodies up top really should be getting you closer to the number you're after.
The numbers are still VERY solid, so don't let it disappoint! I just feel that you should be in the low 5xx's with that setup.
