PRO Engine builders. Brodix head tech question.
SO i was browsing through head and looking into a pair. I was told about the brodix heads by a friend and was told they are pretty good and may work for me. I noticed one note on the heads that has me stumped.
In the description on this head, the 273 BR heads. Second line up from the bottom where it says spring pockets. It says "Spring Pockets: 1.350'' out of the box, May not be cut any larger or deeper"
Is this true? the spring pockets cannot be machined at all basically? Brodix website says this also. I need pockets for a good sized solid roller spring.
http://www.jegs.com/i/Brodix/158/117...ductId=2832322
Moderator
Well I doubt Brodix is wrong since they have that posted on their website, but it does look like there is a BR7 head with 1.650" spring pockets.
Brodix Website
Brodix Website
Moderator
I'd guess that there isn't any room. The one with the larger pockets require longer valves so they probably had to move everything up in order to open up those spring pockets.
Most of the aftermarket heads have to do that. A set of aftermarket cathedral heads I almost bought could accept a 1.550" spring, but the valves were .400" longer and HEAVY!
Yes they can and could allso be angel milled
It would be best to start out with blank castings to get your CC on the chambers atleast or use LSX-DR or CT heads they come with 48cc chambers
kinda wanna sway away from the DR castings being they use only the Dr manifold. would like more options then one gmpp manifold then full custom. Thats why i was looking into these or Edelbrock raw heads.
This stuffs got me about to just build a big block and say to hell with it.
