vengeance 427ci...... more info wanted!!
Here I find myself coming across random videos on YouTube then I stumbled across a mild full weight M6 Camaro 427ci built by vengeance. Well that's all I can find on the car is the video. I want to know more about the car. Do anybody know the car ? It appears to run 10s on motor on the regular basis. Mild 427 Stroker in FULL WEIGHT Camaro SS: http://youtu.be/pMGnVlRHtNU
thanks
thanks
Nearest thing I found 4 U is this WS6 build:
LS3 427ci /235ccTFS / vengeance racing custom camshaft 794rwhp-821tq
just finished up my new build and that's what i got
mods
engine
* LS3 427 ci short block (callies 4.1" crankshaft - 6.125" compstar rods - 4.070" manely -7 flat top pistons)
* TrickFlow 235cc CNC Cylinder Heads (650
Lift Dual Spring - 7.500 Hardened Pushrods -Milled to Spec-68cc)
* vengeance racing custom camshaft 255/259 624/624 114 LSA
* yella terra 1.7 rocker arms
* caddy lifters
* SLP under drive pulley
intake
* SLP cold air intake
* 92mm F.A.S.T big mouth T/B
* 92mm F.A.S.T intake manifold
exhaust
* hooker long tupe headers 1 7/8
* 3" off- road Y pipe
* BOSCH Oxygen sensors
* Corsa Cat-Back 3.5 serious
fuel
* 255 walbro fuel pump
* F.A.S.T fuel rail
* 38lb injectors
ignetion
* LS7 coils
* MSD 8.5 mm plug wires
* NJK TR6 spark plugs
cooling
* Bee Cool radiator
* mezire water pump
NITROUS
* TNT nitrous system adjust to 200hp
* HARRIS speed works plate system adjust to 100hp
*stand alone fuel system (RCI fuel cell - bosch fuel pump - fuel filter - AiroMotive regulator - VP NO2 race fuel 120+ octane )
electrical
* 2 bar map sensor ---> mafless tuning
* AEM Wideband
* MSD Timing Twister
* MSD Digital RPM Activated Window Switch
* Caspers Electronics V-Plus Volt Booster
drive line
* spec cluch kit stage 3+
* spec aluminum flywheel
* tick performance master cylinder ----> DAMN i like it , awesome master cylinder
* RAM slave cylinder
* Spohn Perf. Top-Gun Driveshaft
* Moser 12 bolts rear end 3.4 ratio
** timing 21 degree **
actually we faced a problem with the MSD timing twister or let's say with the wires connections
Therefore, we have not increased timing coz there two stages on board
Dyno results
539 rwhp
521 torque
1st stage (low pressure bottle) air/fuel ratio when spraying : rich
722 rwhp
781 torque
2nd stage (low pressure bottle) air/fuel ratio when spraying : rich
794 rwhp
821 torque
mods
engine
* caddy lifters
intake
exhaust
fuel
* F.A.S.T fuel rail
* 38lb injectors
ignetion
* LS7 coils
cooling
* Bee Cool radiator
* mezire water pump
NITROUS
electrical
* AEM Wideband
drive line
Dyno results
539 rwhp
521 torque
722 rwhp
781 torque
794 rwhp
821 torque
Super nice!! Is the intake ported ? What's the weight on the car and what do you think it would run on motor in the quarter ?
Come on somebody..... someone out there has to know the car LOL. After all it wasn't built in a backyard.
Some People don't want there engine/car combinations out. In fear of someone having the heads up @ the track, if it is known what combination a driver is using we can duplicate it and add a little more compression, bigger cam....etc, for the win and all the money spent to be fast @ the track is gone down the drain. Or what if U class race in the 10 sec index class. Would you like your build specs out?
Doing my personal research and development. If it run 10s all motor with a 6 speed on a drag radial especially 17s I'm very interested.. and not cut to hell and back.
I love seeing real world results of big cube n/a builds. That's just me tho.
Oh, no he wants a read I got it for him. Oh his *** gonna have a Large read, had to go thru my computer files and mags. He's going to need some coffee. Let me switch from tablet to my home computer. He wants info!
When I flew to Michigan in late May to sample Katech's LS7-powered Camaro, it was another track test in another city. Fly in, meet the crew, check out the ride, burn some rubber, have a few laughs, fly home. And this trip was starting out much easier than usual. My departure delay out of New York's LaGuardia airport was measured in mere minutes-a feat I'll be submitting to the Catholic church as an official miracle. My luggage was the first bag out on the belt in Detroit. The mapped directions were actually right for a change as I breezed through light traffic. And the good folks at Katech, in addition to arranging a shop tour, renting out Milan for a day, and pretty much giving me free reign with its LS7-powered Camaro, had also suggested a hotel close to its Clinton Township facilities. It had free cookies and drinks, and upon entering my third-floor room, I found it to be clean and deathly quiet-musta got a room facing away from the street. There were no horns honking, none of the noise typical to a hotel room near a major intersection. Elated with my continued good luck, I moved over to the window and drew the shades to inspect my surroundings. There was a road in the distance, some big shade trees-and hundreds of headstones right under my window.
Despite the restful benefits of sleeping next to a cemetery, I've seen enough horror films to know that this type of omen shouldn't be ignored. You don't go into the woods alone at night, you don't skinny dip at the creepy summer camp-pretty self-explanatory, right? The big question now was: Do you dismiss the superstitious stuff as simple coincidence, or are there repercussions of sleeping next to a boneyard if you are drag-testing the Frankenstein of LS7s the next day?Let's consider what I'd be up against: an LS7 is a force to be reckoned with in factory form, displacing 427 cubes, making 505 horses and 470 lb-ft of torque, and revving past 7,000 rpm in the blink of an eye. The LS7-powered Z06 is capable of mid-11s with enough traction and nerve, a bone-stock rocket with the torque to twist you sideways at every prod of the throttle. Now let's consider the company that modified the LS7 currently sitting in this Camaro's engine bay. Katech Inc. is best known for building the engines for the GM Racing Corvette team-yes, those Corvettes. The C5-Rs and C6.Rs have dominated the GTS/GT1 class of American Le Mans since 2001, laying waste to such rivals as Aston Martin, Saleen, Viper, and Ferrari. They won six ALMS championships between 2001 and 2006, and in that timeframe the Corvettes collected an astonishing 51 victories, including 34 1-2 finishes; multiple LeMans, Sebring, and Petite LeMans wins; and a boatload of ALMS records that may never be eclipsed.
So let me pose one for you: Do you think a company that screws together some of the most ferocious engines on the planet for the world-beating C6.Rs would rest on its laurels when it came time to build a devilish LS7 dubbed "Street Attack"? Not bloody likely.
Starting with an LS7 block and retaining the factory 4.125 bore and 4-inch stroke crank, Katech re-bushes the stock rods and tops them with custom forged pistons. This crew may have learned a thing or two about LS7 airflow during the C5-R/C6.R programs, so you won't be surprised to find a set of worked LS7 cylinder heads atop this mill. The 2.20-inch intake valves gulp air in mass quantities by way of an LS7 intake and UMI 90mm throttle body, and 1.615-inch valves expel air into 1.75-inch TPIS headers and a 3-inch exhaust just as quickly. The heads have been hand-ported to blend out the CNC marks in the runners, bowls, and chambers. Katech also did a little work on shaping the intake runners to extract the very last bit of power. And here's to hoping that all of these tweaks can keep up with the bumpstick, as a positively ginormous 233/276 at .050, .630-lift camshaft calls the shots to the LS7 rockers. Amazingly, a factory Camaro PCM barks orders to this behemoth's LS7 injectors through an assortment of adapter harnesses for the various sensors. Add all of it up, stick it on an engine dyno, and you're left with 640 hp and 555 lb-ft of torque. Yikes.
After sleeping like the dead, I met up with Katech's Director of Aftermarket Operations Caleb Newman and we headed to Milan. We were the last to arrive, as Katech staffers Jason Harding, Dan Shuler, Ken Helzer, and Kevin Pranger had trailered the Camaro earlier so test driver Mark Whitney could make a few half-track runs. A couple of suspension changes had been made since the last track day, and Katech wanted to ensure that the 'camaro was dialed in before I got behind the wheel. In charge of 640 horses, I glanced at Milan's hard retaining walls, remembered a spectacular Enzo Ferrari crash I'd seen on the Interet a few days earlier, and began to appreciate Katech's methodical approach to performance.
The car was ready, and I quizzed the Katech crew on the Camaro and its features. It had a 12-bolt with 4.10s to take hard launches, a Spec 3+ clutch, a new B&M shifter, and a line lock. A set of 325/45R17 M&H Racemaster "street" tires were currently mounted; Mark informed me that he had good luck leaving around five grand in the current trim. I was told that the shift light was set at 6,700 for the day's festivities; my previous experience with the LS7 reminded me that the revs climb so fast, setting a shift point a few hundred low might keep it off the limiter. But no time to digest this new info. It's already past 11:30 a.m., and the temps are in the mid-80s and climbing. Better jump in and make a hit.
After confirming 15 psi rear-tire pressure with Dan, I donned a fire jacket, jumped into the driver seat and adjusted it, then snugged up the five-point harness. On the steering column in front of me sat a round tach and a shift light, and within arm's reach, the line-lock switch snaked out of the console ashtray. I threw on my helmet, rowed the B&M a few times, and cranked 'er up. The Katech LS7 fired off, sending deep bass notes and vibrations through the Simpson padding and into my skull. The 7.0L mill quickly dropped into what could technically be called an idle-the 233/276 duration, 107 LSA cam was chosen for power, not commuting-and I selected First, did a quick spin to kick the pebbles off, and shallow staged. I figured the first run would be a good throwaway; I'd never raced on M&Hs, so I'd leave soft, get used to the launch and tires, shift nice and easy, and feel the car down the track. The light went green, and with the tach on 5,000, I let out the clutch. The tires hooked and the Chevy bogged for a split-second before the LS7 wailed to life, resulting in a ho-hum 1.79 60-foot. It was seven grand before I pulled Second, and a few hundred feet later Third engaged cleanly. The eighth was crossed in 7.4 seconds at 101.3 mph, and a quick shift to Fourth completed the run. No muss, no fuss, 11.39 at 124.9. I immediately rolled back around, intent on upping the revs to leave harder. After a longer spin I rolled up, and when the tree dropped, I had 5,500 waiting for the M&Hs. This launch was smooth, with a 1.61 60 to show for it, but the shifts were not-run over. I missed the gates again 40 minutes later, this time with a 1.69 60 ... and just like that, it wasn't going to be that simple.
Though I slowed down and made damn sure I hit all the gears in the next few passes, two were mid-11 runs and only one improved on my best-a 1.72 60 with some wheelspin resulted in an 11.34/124.3.
At this point, the smart move was to put Mark in the driver seat; he had the most time in the Camaro, and if we were to see a 10 on the street tires, he would do it. His first run was a throwaway, but the next one was solid-he really punished the M&Hs off the line, feeding in more throttle and letting them spin, as opposed to my using less throttle until I knew the meats were planted. And it worked. A 1.66 60-foot resulted, and an 11.15 at 122.8 flashed. His next was even better, as the hard launch ripped the Camaro sideways to a 1.61 short time, and it blazed through the traps in 10.94 seconds and 126 mph!
The ad jockey posted a hell of an e.t.; it was now time to mount the slicks and save a little face. Even though the M&Hs were damn sticky, I felt much more at ease with the slicks on. The Katech Camaro possessed way too much power for some editor with only a few minutes behind the wheel to roast the hides and skate down a dragstrip on treaded tires. To be honest with you ... this car was a bit scary. Not poor-suspension scary. Not even Christine scary (though both Steven King's '58 Plymouth and Katech's Camaro have the power to easily do you in). No, this kind of demented power meant dancing with the devil at every throttle prod, and on treaded tires, the devil had the edge.
The Hoosiers were bolted on and it was back to the staging lanes-our track rental was coming to a close, and I had about 15 minutes to wring this sucker out.
Now packing front skinnies and 28x10x15 slicks, I pulled into the box, set the line lock, and did a massive burnout to fully heat them. The first run was nothing special, an 11.4. While coming back around, I decided to take the same approach with Katech's LS7 as I did with the GMPP LS7 Camaro: big burnout, near redline launch, quick shifts. After the big smokey, I shallow staged, took a deep breath, selected First, and let the revs climb past 6,000 before dumping the clutch. The Hoosiers bit hard, but still not as hard as I was hoping for, and propelled the F-body to a 1.61 short time. The LS7 was liking the higher-rpm launch, and sang loud through three gears, banging out a 10.97/124.63.
But as great as that 10 felt, there was more in it. Though we were officially done for the day, the Milan staff was cool enough to let me make one more hit. A five-second burnout and I was shallow staged and waiting for the tree to come down. Once it did, I took a deep breath ... flattened the throttle until I saw seven grand...and sidestepped the clutch.
The nose shot into the air-it was a perfectly straight launch that yanked the front tires up a couple inches, giving me a priceless view of blue sky. When the front end came down, the Hoosiers screamed bloody murder and struggled to grip Milan's sticky surface. The monstrous LS7 needed another gear, so I fed it Second in a hurry. When it got Third, I'd passed the eighth-mile in 6.9 seconds. The only hiccup happened at the top of Third gear, as the shift light never blinked for Fourth and it hit the limiter. I quickly banged the last gate, and the clock flashed 10.86 126.4.
Three hot laps in the span of eight minutes. Ninety-degree temps. High density altitude. 10.8s...
The next day, the Katech crew offered me the keys to the Camaro as we headed out for lunch. The adrenaline and elation of the previous day had passed, replaced with New York skepticism. It was possible that in the next hour, I'd be breaking out the old "No! No problem that your thinly veiled race car died in traffic ... I'll call AAA ... Don't worry about it, I've got 'em on speed dial. By the way ... those shocks are hooked up, right?"
Standing in front of the building, I heard the unholy beast start up, then it rumbled around the corner with Jason driving. He hopped out, and I navigated myself through the 'cage and reached for the seatbelt. "Does this have the factory belts?" I asked. "Nope, you'll have to use the harness." And it begins ...
But two hours, four tacos, and one personality-delete waitress later, I arrived back at Katech with a smile and without a good amount of tread on the tires. It didn't stall (though with that cam, it had every right to), handled fine, braked well, and scared the bejesus out of the Mustang driver behind us as I went WOT through two gears.
Which begs the questions: Do we really need 427-powered Katech Camaros terrorizing the streets? Cars that'll do 10s at the strip on your choice of tire, and are a cam, a seat belt, and a catalytic converter away from a commuter car? Should the public even be allowed to buy one of these minions, able to tempt good God-fearing folk with the dark power trip of opening this LS7's throttle, hearing the Flowmaster shriek, and feeling like they just opened up the gates of hell?
I'll struggle with my demons ... good luck with yours.
Thats what you asked 4 ?
Cause your are doing your own personal research and development. If it run 10s all motor with a 6 speed on a drag radial especially 17s I'm very interested.. and not cut to hell and back.
Well here you go, btw this is a very old article.
He wanted info LOL!
He wanted info LOL!
Maroonls1z I'm gonna get him, watch this 10's with a 408 build. Hmmmm I think I got one of those with better stuff. Bored watching the Arizona and Carolina. Here goes some more info
Ole buddy ole pal. LOL! Oh yeah, all have complete interiors.
Over the years, the Camaro has been continuously modified. It currently sports a 402ci stroker that utilizes an LQ9 truck-based LS engine block. This potent combo puts down a brutal 550 rwhp on the Dynojet. This full-weight street cruiser gets it done at the track as well, with a current best e.t. of 10.70 at 131 mph.
Michael's ultimate goal is to make the car a 9-second street car. He has recently installed a 250hp wet nitrous system, bringing the total horses up to 700. No track times on that combo yet, but that's more than enough power to get into single-digit territory. After that goal is achieved, a new project car will be built with his dad. They have a 1969 Camaro parked next to this one, just waiting for its turn under the wrenches and paint guns.
So there you have it, the classic story of boy wants hot rod, boy gets hot rod, boy meets girl, boy chases and catches girl, and keeps the hot rod, too. The happy couple is expecting a baby boy soon-who will no doubt be the next little grease monkey in this family. I'm betting junior's first ride home from the hospital is in the flamed Camaro. May his first word be "Vroom!"
DATA FILE Car: 2001 Chevrolet Camaro SS Owner: Michael & Janelle Dietze Engine block: LQ9, 402ci Compression ratio: 11.7:1 Cylinder heads: TEA modified Trick Flow 225cc Intake: Fast 90mm composite Cam and specs: Hydraulic roller, 248/256 duration at 0.050, 0.602/0.622 lift, 114+2 Pushrods: Comp Cams 7.450-inch Rocker arms: Harland Sharp 1.7 ratio roller Pistons: SRP Forged Rings: SRP Crankshaft: Eagle 4-inch Rods: Eagle 6.125-inch Throttle body: Nick Williams 90mm Fuel injectors: Ford Racing, 42 lb/hr Fuel pump: Racetronix 255 lph Ignition: Factory coils with NGK TR6 plugs Engine management: Factory PCM, owner tuned with HP Tuners Nitrous system: Nitrous Dave's custom 250hp shot wet kit Exhaust system: Custom Spin Tech 3-inch oval true duals Transmission: Six Speeds Inc Stage 2 T56 six-speed manual Clutch: Spec solid hub 3+, aluminum flywheel Driveshaft: Spohn chrome-moly Front suspension: Factory A-arms with QA1 adjustable coilover shocks Rear suspension: Madman full suspension kit with AFCO double-adjustable shocks Rear axle: Moser 12-bolt, 31-spline, Truetrac, 4.56 gears Brakes: Brembo cross-drilled with Hawk pads Wheels: American Racing Torque Thrust-M 17x9 front, 17x11 rear Front tires: 275/45/17 Goodyear Eagle F1 Rear tires: 315/35/17 Goodyear Eagle F1 Fuel octane: 93 Dynojet results: 550 rwhp and 502 lb-ft (without nitrous) Race weight: 3,780 lbs Best e.t./mph: 10.70 at 131 (without nitrous) Best 60-ft time: 1.65 sec Current mileage: 123,720 Miles driven weekly: 230
I'm back in the house!! I've read up on those two cars there. Both the 402 LQ car and the 427 Katech car! Both are badass! Honestly that's the largest split duration I've ever seen on a cam period on the LS7 car. I just find it fun keeping up with cars like this as I slowly perfect mine for my usage. On the LS7 headed 434ci build.... When will I have some track numbers? :-)
I got a notebook with a couple of solid combos that get the job done but they are mostly old. The more combos the better I feel about taking on the challenge. Lil John you mention a 408ci bro..... keep me posted please. I'm paying very CLOSE attention to every all motor build that comes up across this site especially if it's a 4th gen Camaro like my 2000 Z28. Also I'm watching Tony Mamo closely especially since he went solo.
