6.0 max bore?
6.0 max bore?
I'm wanting to bore my 6.0 iron block from 4.030 to 4.070 and fill the block half to 3/4 way with hard blok.... going to be spraying 300 to 400 shot dry nitrous.. compression going to be around 12.1 to 12.5 .running holley efi race weight around 3000lbs...anyone ever bored this much on 6.0 block thanks in advance
This has been discussed on here many time.
One block might be fine and another not. The bottom line is you need to get your block checked to find out the thickness of your cylinder sleeves.
Ive got a 4.065" bore on an LQ4 block, with no filling, and sprayed 150 a few times...no issues at all. its gonna get a Procharger sometime soon. The nitrous is quite a bit harder on the engine than around 12-14 psi of boost will be. I got lucky that my block doesn't have core shift issues though. I have a friend locally who had a 416ci with an iron block (4.065" bore) with an F1A procharger that split a cylinder.
Camster, said it right stay @ .030 over bore You will Not see that much of a improvement if any, but the Reliability of the block will be compromised with anything other than a N/a 6.0 build. Factor in the block is now useless once bored over .065 - .070.
