Gen III to Gen IV cam timing
Old 07-02-2015, 08:27 PM
Blazeracer's Avatar
Default Gen III to Gen IV cam timing
Hey all, I'm fixin to go from a Gen III LS1 to a Gen IV stroker. Is there a way for the front timing setup to work with my Gen III 24 tooth MSD for the cam timing? Did a search and didn't find anything but a bunch of tech manuals.
Thanks in advance.
Old 07-02-2015, 10:43 PM
DietCoke's Avatar
The crankshaft wheel is what determines timing, not the front cover.
Old 07-02-2015, 11:23 PM
Blazeracer's Avatar
So whether it's a 24 or 58 tooth reluctor wheel, the cam sensor doesn't matter?
It's the same sensor if it's in the back of the block or the front cover??
Obviously I'd have to lengthen the connector, but my MSD-6LS will work with the cam sensor in the timing cover???
Right now I have a Gen III with a 24 tooth wheel and the cam sensor in the back of the block. You can't get a new block with the cam sensor in the back any longer. If it doesn't work I'll get a new MSD and a stroker kit with a 58 tooth wheel. But, would rather not buy another MSD if I don't have to.
So the question remains, will an MSD-6LS for a 24 tooth reluctor wheel work with a cam sensor in the front cover?
Old 07-02-2015, 11:24 PM
DietCoke's Avatar
The sensor just has to match whatever is on the crank wheel. You want a black or grey cam sensor, part #12600325 is the ls2/24x front cover sensor.
This has some good info that may help you out
http://www.ls2.com/forums/showthread...-in-an-LS1-car
Old 07-03-2015, 04:44 AM
Blazeracer's Avatar
That's exactly what I needed to know, thanks.
Old 07-03-2015, 07:14 AM
MuhThugga's Avatar
LS1Tech 10 Year
You'll need a Gen IV front cover, a 1x timing gear, and the matching 1x cam sensor.
Racetronix makes a nice extension harness for the new sensor location.
You will also need to drill and tap the sides of the block for the Gen III knock sensors and get/make the extension harness.
Old 07-03-2015, 06:17 PM
Blazeracer's Avatar
Yeah, I read the entire article that was linked. I run a carb, no knock sensors needed. Will definitely look at a Racetronix harness extension.
Old 07-03-2015, 09:35 PM
DietCoke's Avatar
Originally Posted by MuhThugga
You'll need a Gen IV front cover, a 1x timing gear, and the matching 1x cam sensor. .
Either cam sensor works.
Quick Reply: Gen III to Gen IV cam timing
