LS 408 build for dirt modified (***with pictures***
Old 08-16-2015, 08:48 PM
thfleshman's Avatar
Default LS 408 build for dirt modified (***with pictures***
short block complete with all forged compstar crank and H beam rods with total seal rings on Manley 4.030 pistons
wanting to run alcahol on this but If I cannot find any info such as what plugs to run I will run this carb but really have my heart set on running alcahol
double roller timing chain installed and cam degreed
just showing all the adjustment possibilities with this timing set
installing my chromoly pickup tube that came with my custom made oil pan
showing my melling high volume race oil pump and again installing pickup tube
head studs going in and showing off my LSx valley cover
test fit of my super victor intake
my custom oil pan and heads installed (ported/polished LS3 heads with Pac springs)
motor almost completed with my powder coated valve covers
Old 08-16-2015, 08:49 PM
thfleshman's Avatar
I wish I had taken pictures of me degreeing the cam but didnt think of it until after I was done should be a good reliable motor and will continue to add pictures as it is 100 % completed
Old 08-22-2015, 09:13 AM
Mean87SS's Avatar
Looks good... what trans do you run?
Any other guys running LS motors? Are you limited to a CI or?
Old 08-26-2015, 12:32 PM
thfleshman's Avatar
Thank you I run a Bert transmission it is a 2 speed direct drive transmission with internal clutch for low and reverse gear no one yet around my aera is running ls but the guy who built my chassis has one but since some has heard about mine there has been some more interest as for the cubic inch question no we do not have a limit only limitations are must be carbureted,(only 1 aloud) have a Steel block and some places mandate mufflers inserted in headers
Old 08-26-2015, 12:37 PM
thfleshman's Avatar
This is the most recent photo from my build I have had a lot of stuff come up over the last week or two so have not got to work on it much have had a lot of on/off Mach up before final assembly and have had a few hold ups along the way but very pleased with the outcome this far
Old 08-26-2015, 12:48 PM
A.R. Shale Targa's Avatar
VERY COOL.....
Old 08-26-2015, 12:59 PM
thfleshman's Avatar
Originally Posted by A.R. Shale Targa
VERY COOL.....
Thank you! Hope to have it in and fired very soon then chassis dyno!!!
Old 08-27-2015, 12:13 PM
hiltsy855's Avatar
Awesome. Clearly not a claimer class motor!!!
Old 08-27-2015, 06:35 PM
Crazy rules right there or lack of shal I say. Most mandate an iron head, flat tappet camshaft and a distributor with no box. What you have there will easily top six hundred ponies and you're a laptop computer away from basically having traction control when the track goes away as most dirt ones so. 👍
Old 08-27-2015, 11:23 PM
thfleshman's Avatar
There is actually still a claim rule in place and believe it or not it is still only 550$ to claim but in my 10 years of dirt modified racing I have yet to see a claim happen I am hoping for reliability out of this engine not overly concerned about max hp numbers I am more concerned with drivability and reliability but I still hope it is somewhere between 600 and 650hp very excited to get it going
Old 08-27-2015, 11:29 PM
thfleshman's Avatar
Engine is all but finished waiting on a few parts and it's time to drop it in!
Old 08-29-2015, 07:59 AM
looks awesome....I do see only the one valley cover breather as crankcase ventilation ????
Perhaps look into the evac kit that drag racers use with some nice fittings in the drivers side valve cover and one vent hose to each draft bung which gets mounted in the header collector. It's less effective than a Vac pump but still does wonders for preventing oil leaks, preventing ring flutter, and adding power. RING SEAL is everything to making reliable power......
Old 08-30-2015, 12:06 AM
thfleshman's Avatar
i still plan to vent the valve covers as well the valley cover is a custom addition with a baffle inside mainly for filling with oil easier and cleaner than through the valve cover I have looked and tried to find info on how to vent without pumps or having a pcv system and had no luck I'll just be honest I didn't have a clue what I was doing or even if it would work my new valve covers I just ordered (my factory won't fit over my pro mag rockers like comp cams say they will) will have a breather like this one welded up so a breather can fit in them like my valley cover
Old 08-30-2015, 11:48 AM
http://www.summitracing.com/parts/mor-25900
just add hose
Old 08-31-2015, 01:20 AM
thfleshman's Avatar
Thank you! Does anyone here know of anyone with good info on what plugs to run with alcohol and anyone ran alcohol with the msd 6010 setup?
Old 09-07-2015, 06:04 PM
thfleshman's Avatar
Motor is sitting in the car it's been a slow process with working 12 hr days doing it mostly alone. I also had to get new valve covers due to stock ones not fitting over my pro mag rockers
Old 09-08-2015, 08:57 AM
Its Stock's Avatar
That's awesome! What are you running for exhaust? Just those headers or are you guys required to run mufflers and have a dB limit?
Old 09-08-2015, 06:17 PM
thfleshman's Avatar
just headers thats it some tracks do require mufflers but they are basically just a screen inside the header they really don't do much at all for noise control.
Old 09-11-2015, 01:16 AM
96LT1Z's Avatar
Lol at showing your entire setup to the world right now. No secrets here
Old 09-13-2015, 12:41 AM
thfleshman's Avatar
I don't have anything to hide bud no sense in keeping it from anyone I'm proud of it and besides no one runs these engines in my class
Quick Reply: LS 408 build for dirt modified (***with pictures***
