No, the plugs are keyed differently. You might could use the old one by sawing a new key slot, but they are different and will not interchange as-is...
That's odd, cause in my C5 they were the exact same. When I installed my LS2 years ago I forgot to swap them out. I found out when I tried to fire it.
The 58x wheel takes the gray sensor and uses this connector, while the 24x wheel needs the black sensor and this connector. If you look closely at the "key slots" they are different, not to mention the pinouts are different as well...
Public Service Announcement: Don't try to answer questions while you're on drugs in the Dentist's chair.
I was thinking about my oil level sensor. Oops.
