Valve springs for .600+ lift cam
I'm interested in hearing opinions on good valve spring choices for a cam with .620 lift. Most I've talked to already recommend a dual spring. Anyone using a beehive spring with a high lift cam with success? Granted I realize that with beehives you lose the safety net of a dual spring but are any holding up with success. Thanks for any advice or suggestions
Well......you really should be looking at a good double spring set.
BUT.......if you MUST go with a beehive spring, the ones that are rated in the .625" range is pretty risky way to go.
I would go with the COMP Cams 26095-16 spring set. These springs are rated to above .700" with a spring pressure rate that won't destroy a good hydrualic roller cam.
KW
KW
What is the combo? PSI makes some sick beehives!
I personally run PSI1515MLs on mine with .661lift and 7300RPMs and will be moving to PSI1516ML with my new cam.
Check 'em out!
Check 'em out!
