Can you put a Gen III cam into a Gen IV motor?
Old 07-30-2004, 01:19 PM
Moderator
xp3nd4bl3's Avatar
Default Can you put a Gen III cam into a Gen IV motor?
That would have to be mod #1 on an '05 6pd GTO.
Old 07-30-2004, 01:26 PM
BADFNZ's Avatar
I don't think the cam sensors are in the same place so I'm not quite sure.
Old 08-02-2004, 01:02 AM
FASTONE's Avatar
The ls2 is an improved ls1,just improved,should fit!!
Old 08-02-2004, 12:15 PM
LS1 Tech Veteran
Steve Bryant's Avatar
I agree, I see no reason why the existing LS series cams wouldn't fit the initial LS2. The displacement on demand versions may have some lobe lift limitations and the eventual rumored three valve version might have some differences (but I even doubt that). As was stated, the LS2 is an improved LS1/LS6, but it is still in the LS series.
Steve
Old 08-02-2004, 06:33 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,222 Likes on 779 Posts
LS1Tech 10 Year
The cam sensor is rumored to be in the front. So that would mean that the cam sensor reluctors on the camshaft would be in a different spot. I'm waiting for someone to post some good pics. We need a nice shot of the engine sensors on a C6 engine.
Old 08-02-2004, 08:52 PM
LS1 Tech Veteran
I think that you're right and I'm wrong. I did some searching on Google and here is a good summary from the National Corvette Museum on the LS2 http://www.corvettemuseum.com/specs/...wertrain.shtml. However, I'm sure that Comp, Crane, Lunatti, and everybody else will have cam grinds quickly once the blanks are available with the front-mounted reluctor wheel.
I'm really curious what they might be developing in a truck counter part (like a 6.6 L Stroker with a 4.00" bore and a 4.00" Stroke)
Steve
Old 08-03-2004, 01:20 AM
Scott Turvey's Avatar
Steve
From what I've heard, the 6.6 is being looked at for '06, and possibly in an aluminum block.
Quick Reply: Can you put a Gen III cam into a Gen IV motor?
