LS2 intake ? for sdpc
Old 10-12-2004, 11:36 PM
wildta's Avatar
Default LS2 intake ? for sdpc
How does it compare to LS6 or a LSX ? Does it flow better than the LSX What is is this tb so saught after ?
p.s. Looks Nice !
Old 10-13-2004, 06:01 AM
Camaroholic's Avatar
It's $600 cheaper than the LSX and has a 90mm opening. You have to do a little work (fuel rails, extend MAP sensor) to make it work... But that $600 could be the cost of a nitrous kit.
Mine should be here by Friday.
Old 10-13-2004, 07:46 AM
Squintz Palladoris's Avatar
Mine will be here next week
Brad
Old 10-13-2004, 07:47 AM
Have to make a brackett for your throttle cable brackett as well.
Brad
Old 10-19-2004, 07:32 PM
Danny2tek's Avatar
Old 10-21-2004, 09:27 PM
WS6FirebirdTA00's Avatar
so what all has to be done to make this work, EVERY part needed, TB and all. cause im thinkin about gettin a cam and i figure why not get this intake since its so damn cheap. and where can i get it? and how long will it be cheap
Old 10-21-2004, 09:41 PM
SCPC is selling all the parts you will need for around $820. That includes a Fast 90mm TB. You will have to Fab up a brackett for the throttle cable.
I hacked up my old ls1 intake and epoxied it to the intake.
I just need the TB now. I am waiting on funds for that.
Brad
Old 10-21-2004, 11:11 PM
U LUZ's Avatar
This Is Good To Know Since I Just Spent 1500.00 In This Piece Of Plastic...
Old 10-22-2004, 12:44 AM
screamin00ss's Avatar
does that 820 include injectors...if so what size are they...
Old 10-22-2004, 04:02 AM
thats using your current injectors.
Brad
Old 10-22-2004, 08:42 AM
The $820 includes the LS2 fuel rails, which price out at about $129 or so. I opted not to go with the fuel rails, since I'll probably upgrade to some billet units anyway. I'm just going to hack my LS1 rails to "get me by" until I'm ready to upgrade the fuel lines & rails.
Old 10-22-2004, 08:46 AM
I have 2 ls1/6 rails if any of you are interrested.
FWIW the ls2 rails are larger and they do hook up to the factory fuel line.
Brad
Old 10-22-2004, 11:26 AM
for 400 bucks and just a little bit of imagination you can have this set up for the same price u can get an ls6 set up. just have the same tb. i have a real good idea on what to do so if someone has an ls2 they can give me some dimensions on i can fab up a trottle body adaptor with a bracket built in. or if anyone wants to let me borrow one so i can do this in the machine shop. this would be a great project for my design class next semester at unc charlotte lol
Old 10-22-2004, 11:52 AM
You can come by my place n take any measurements you need. I am in Fayetteville, NC. Drop me a PM
Brad
Old 10-22-2004, 12:48 PM
um, i would but i kinda lost my license haha. let me go home and look at my car and ill try and see what i need measured, shouldnt be much. just like the length and stuff. i seen a link with a whole lot of pics of the intake, does anyone know where that is now i cant find it
Old 10-22-2004, 12:50 PM
Let me know waht you need measured. I can take some pics too.
Brad
Old 10-22-2004, 03:33 PM
ok i need pics of the throttle body region, the length from the front bolts that hold the manifold down to the opening in the manifold where the TB goes, dimensions of the flat spot where the TB bolts up to. are the bottom holes the same as the ls1 tb? hmmm thats all i can think of right now if i think of anythign else ill let you know what im lookin for. ive got the bracket all figured out, it will look factory, when i get it made ill post some pics, as for the adaptor i drew something up but ill have to check all measurements first.
Old 10-22-2004, 04:01 PM
um, 98-2000 do i need to change the coolant tubes ? looks like it has some clearance
Old 10-22-2004, 04:03 PM
and those intake ports look nasty, they easy to clean up with a dremil?
Old 10-22-2004, 04:10 PM
Yes you will need to get rid of the X coolant pipe and get the ls6 style coolant tube for the front and plug the rears.
Yes, I spent about an hour or so cleaning them up with a dremel tool.
Here are som pics of My "Factory Looking" Brackett
Quick Reply: LS2 intake ? for sdpc
