ls7 clutch compatible with ls1?
Still trying to make sure, but it sounds like LS7 clutch will work, must have LS7/LS2 flywheel, Scoggins indicated part numbers same for LS7/LS2 flywheel. $499 for clutch kit including clutch, pressure plate, throwout brg, flywheel.
See also thread from 'LS7 Clutch Installed Today'.
1. Clutch - 24233650 - $274 Scoggins
2. Flywheel - 12571611 - $161 Scoggins
3. Kit w. throwout bearing - TBD part number - $499 Scoggins
Also something I am debating is that I already have a new slave and throwout bearing but with the kit, it is a balanced assembly; clutch and flywheel marked just like the LS1 or LS6 kit. Is it really necessary to have a balanced set - that is where GM stuff makes the difference sometimes ?
I did not balance mine and it works fine. I know it's not a kit with the flywheel, but I thought the pressure plate was balanced from the factory and so was the flywheel???
