GM LS7 hot cam
Old 05-25-2006, 04:30 PM
pcf_mark's Avatar
Default GM LS7 hot cam
Does anyone have any part numbers for the new LS7 hot cams featured in Hot Rod a few months back? Nothing in the new parts catalog either.
Has anyone installed and run one yet?
Old 05-25-2006, 05:43 PM
11 Bravo's Avatar
What is this?
Old 05-25-2006, 06:59 PM
GMW-CSL's Avatar
I, too, am interested in finding an LS7 cam with about the same lift as the stocker but with a little more duration, i.e. low to mid 230s. I'm running a 222/226, .570/.570 cam in my LS1/6 now and its street manners are perfect but I'd go a little bigger next time. The mid 230 LS1/6 cams by Comp and Crane will evidently fit but with the 1.85 LS7 rockers would produce way more lift than I want. Jason at Katech says they are testing some cams now.
Old 05-26-2006, 06:44 AM
pcf_mark's Avatar
I can only answer what I read in Hot Rod. GM has two cams for the LS7 they call hot cams similar to hot cams in the past. One version is a drop in - no changes to any other hardware (springs, rockers, retainers) and picks up ~40 HP. The next one is a more serious and requires the user to install new valve spring retainers (to get more height to prevent coil bind) but otherwise drops in. I think this was worth 60HP. GM has the time, money (?) and sophisticated tools to develop a good cam with long life.
Old 05-26-2006, 07:30 AM
DrkPhx's Avatar
I have the issue. I thought they listed the part numbers. If not, call Katech the engine dyno runs were performed at their place. They might have additional information.
Old 05-26-2006, 09:45 AM
LS1TECH Sponsor
Katech_Jason's Avatar
Hey guys,
We've been testing cams this spring. We're just not ready to announce any information until everything is exactly how we wait it.
As for the GM cams we are awaiting the release of the cam through the dealer network and can't give out any additional information at this time.
Old 05-27-2006, 01:46 PM
AU N EGL's Avatar
I found this in a Hot Rod mag a few months ago( Feb 06 issure) about the LS7 Hot cams. Not sure if these are correct or not.
230/231 591/591 116
227/239 583/583 ?
233/276 630/630 ?
Old 05-28-2006, 09:05 PM
msb184's Avatar
Default HOT ROD misprint
I assume the 233/276 is a misprint in HOT ROD. Does anyone know the correct #'s on that one?
Old 05-29-2006, 01:29 PM
Bowtiejoni's Avatar
Anything new on these "hot cams" ? Was there any dyno graph to see how is low end torque vs stock LS7 cam ?
Old 05-29-2006, 01:36 PM
GMW-CSL's Avatar
I'd really like some reliable info on LS7 cams using stock 1.85 LS7 rockers too
Old 05-29-2006, 01:41 PM
Bowtiejoni's Avatar
Who build and tested that engine in Hotrods project? Is here any members close to hotrod mag ?
Old 05-29-2006, 11:25 PM
HotRodV6's Avatar
Yeah i think thats a typo in the mag, althought for the stage 3 cam they did list groos cam timing (degrees) as 294 int 335 exh so maybe its right, and since they didnt list the LSA for any of the cams, im going to assume that they retain the stock LS7 116 LSA??
At the end of the article they listed a prototype carb intake for the LS7 that made almost identicle numbers as the EFI and should be released some time soon, and they said that the same intake will be released for the L92 heads as well.
No part numbers for anything in the article.
Quick Reply: GM LS7 hot cam
