Injectors, fuel rails for l76 intake
Closed ex-Sponsor Account
Originally Posted by forgedbluess
Short question for you guys to answer for me, what injectors and fuel rails can i use for the l76. If it matters its a 00 camaro ss.
instead of jumping to conclusions...
how much are you spraying and i'm guessing it'll be a huge shot, so you have a dedicated fuel setup for nitrous.
so what's the motor setup then. you have to worry about injectors for the MOTOR setup. unless you are doing a dry shot as a first stage or something
Motor is a 370 with about 11:5:1 compression, l92 heads, l76 intake, custom nitrous cam, and everything else to handle a 400 shot on 2 stages. I want to do a plate system and a direct port setup on 2 stages. 200 out of the hole and 200 as soon as i hit second gear. Motor should make close to 475rwhp if not a tad more and im shooting for close to 900rwhp on spray.
