LS2 double roller timing chain
I can shift faster than you.
The timing sets fit fine with an LS6 style pump. You do have to clearance the Melling pump with any double roller, though. I have never had to clearance the front cover.
Jason
Jason
I was planning to use the Melling oil pump with a future L92 build and was wondering about this. I would like to use a double roller, but if a single will work on a radical setup, then so be it.
My double roller Rollmaster came with spacers for the oil pump, but I didn't have to do any clearancing on the front cover. This is of course on a LS1. What I want to know, with my future L92 block, using the Melling oil pump, will I be able to use a double roller and if so, will the pump or the timing cover need to be clearanced?
