Crane valve sprig tool with L92 heads (will it work?)
That is a good question. I didn't even think about that. I have the Crane dual spring compression, but never put any thought into it as far as using it for a L92 head. Hopefully someone can confirm.
Have you tried the KD tool?
I have the KD tool that works on the LS7 heads (which are similar to the L92 heads). It comes very close to contacting the rails - I even had to grind some clearance. I called KD and they do not have an extension for their compressor.
SLP has a good price on their valve spring tool. It comes with the longer extension for taller springs. It also comes with a air hold fitting set.
http://www.slponline.com/view_product.asp?P=53306
