ls7 block with ls1 eagle crank?
like the title says, if i do this, can i run the ls1 oil pump and oil pan and front cover, also if i decide to go this route, can all of my accesorys go on my ls7 that came off my ls1?
eagle crank 4'' and pistons
can i use knock sensors in the same place, obviously i would have to get some aftermarket heads, but beside that can i just us all of the parts of my ls1
Yes.
You will need the pan and pickup for the vehicle type you are putting the engine into (ie truck, fbody, gto, or vette).
I would recommend going with a ported LS6 oil pump -vs- a stock ls1 as it has better flow.
Do NOT get a L76/L92 oil pump as they put out to much pressure for a non-AFM engine.
Actually both SDPC and Texas speed offer shortblocks with the ls7 block, 4" ls1 style crank, rods, pistons, pump, and what not.
Oh and if you are retro'n the LS7 block into a LS1 vehicle you will need to follow the ls1 to ls2 conversion spec's. The LS7 is like the LS2 and uses the cam gear for cam timing -vs- a sensor in the block reading from the cam.
Look through the different stickies and you should get an idea of what is needed to make a wet sump ls7.
i just found the sticky thnx any way, i was wondering though, i heard that the ls7 has the ls1 knock sensor location in the same place, if so,that means i wont need extensions for those right, all of the oil system will fit on the ls7 as long as the reluctor wheel is a 24 coreect? correct me if im wrong plz
No, the knock sensors do get relocated to the sides of the block. You will need the extension harnesses. The harnesses (Katech) make the while operation plug and play. You use the LS2 valley pan instead of the LS1 valley pan. The LS2 valley pan does not have provisions for knock sensors so that is the reason that the relocation is necessary.
SDPC can set you up with everything that you need. That is where my stuff came from.
The LS1 oil pan will work fine. I converted to the LS2 pan (Corvette) since it has better oil control. The LS2 pan gets rid of the bat wings and makes for more room to install/remove headers, get to the starter, etc.
Make sure that you get your LS7 block drilled for a dip stick. I don't think that they come that way. SDPC took care of that when they did the shortblock.
10 & 11 Second Club
It idles nicely at 900 with a little bit of lope.
Originally Posted by Caveman
I am thinking about doing the SDSC 427 setup w/L92-L76 with my 2002 Formula, I see you have a smallish cam for a 427. Does your combo idle good and calm or is it nasty like most big power engines?
