GM CNC L92 Head Results!
Old 11-12-2007, 09:29 AM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
Default GM CNC L92 Head Results!
Ok, we did a back to back swap on the engine dyno. The engine is our L92 427. We were running an L76 intake, box stock. The only change made between graphs was the heads themselves! We not only put the HP and FtLbs figures, but highlighted the difference between the runs in yellow for easier reference.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 11-12-2007, 09:32 AM
Kleeborp the Moderator™
MeentSS02's Avatar
Solid gain...you didn't have any numbers below 4500 RPMs?
Old 11-12-2007, 10:48 AM
bandit1's Avatar
what size amare you guys using and also if the customer has a set what is the cost to have them cnced or can they have it done???
Old 11-12-2007, 10:50 AM
What size of what are we using? Unfortunately, we cannot send your heads off to be CNC'd, we only sell these heads CNC'd out of the box.....however Jason@PRC could probably take care of you on that!
__________________
Old 11-12-2007, 10:58 AM
bandit1's Avatar
sorry I meant what size cam are you using?? How much are the heads and are they avaliable with hollow stem valves and what springs would you go with for a 238/254 609/598 114 camshaft??? I have the stock out of the box L92s and 918 comp springs and stock valves it makes good power 505 rwhp on a dynojet but I feel theres more in it. I have 1 7/8s kooks with a true dual custom 3in exhaust and looking at getting the new starr intake when it comes out.
Old 11-12-2007, 11:03 AM
It's a low 230's duration on the intake side...pretty mild for those cubic inches!
We do offer a version of these heads with a Manley stainless steel valve, but not a sodium filled.
__________________
Old 11-12-2007, 01:29 PM
chipabba's Avatar
Looks killer! Can we see the entire graph? Any plans to offer a turn-key or long block with this set-up or are do we have to go through Mast?
Old 11-12-2007, 02:02 PM
That's all the graph we've got. We can put these heads and an intake on any of our short-blocks (4.0"+ bore of course)!
__________________
Old 11-12-2007, 02:28 PM
94 guy's Avatar
where about is the lift and ex. duration?
Old 11-12-2007, 02:36 PM
Exhaust duration is low 240's...lift is about the .600" mark.
__________________
Old 11-12-2007, 02:51 PM
Redlinez's Avatar
About what would that come out to as a longblock complete? I added up about $7400 plus or minus a few
Old 11-12-2007, 02:57 PM
That all depends on what short-block, which components you want, etc.
__________________
Old 11-12-2007, 03:03 PM
Phoenix 5.7's Avatar
very nice power. that is some serious gains. can't wait till i can start my build.
did it seem like the L76 intake is holding it back up top? supposively the L76 is only good for around 6000rpm. don't supposive yall could do a carb style/l76 intake comparo with those heads.
Old 11-12-2007, 03:15 PM
The intake is definitely holding it back...look and see, the peak HP is 6200-6300rpm still, same as you see on all these intake setups.
We had to ship the engine already so it might be a little while before we get ready to do a back to back intake test.
__________________
Old 11-12-2007, 08:16 PM
ramairws6's Avatar
Do you have any porting offers and #'s for the LS7 heads yet?Traver
Old 11-12-2007, 10:51 PM
rking's Avatar
Whats the price on those bad boys??
Old 11-13-2007, 08:08 AM
CNC L92 Heads @ SDPC
__________________
Old 11-13-2007, 05:56 PM
Bink's Avatar
Originally Posted by Matt @ SDPC
Amazing!!.....heads that flow like these and relatively cheap. Great buy!!
Old 11-13-2007, 09:12 PM
adams2003's Avatar
Is that per head or for the pair?
Old 11-14-2007, 08:15 AM
Those prices are for single heads.
__________________
