GM says LS7 heads require a minimum 4.100 bore, anyone tried them on a 4.080 bore?
Here's my logic: if you can swap run the LS3 heads (with giant 2.165 intake valves that are meant for a 4.065 bore) on to a smaller 4.000 bore without problems, I would think you should be able to run LS7 heads (with only slightly larger 2.20) valves on a 4.080 bore. Anyone tried it?
Figure I've got an LS3 block bored to 4.080
i would stick with what gm says-min of 4.100 bore-
LS1Tech Premium Sponsor
we're working on a 4.095 bore l92 configured with PRC CNC Ported LS7 heads! Look for testing & results shorlty!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
Assuming the valves don't actually touch the sides of the cylinder bores, wouldn't it be more important to determine how well a given head/bore size combination moves air, and choose the head and bore size from that information?
I'm not advocating a minimum bore size, just looking for more power. There are lots of ways to get from here to there BTW.
Jon
Jon
Grab an LS-7 head if you have one laying around or borrow one from your friends. Bolt the head onto an empty block and reach your hand down into the bottom of the cylinder. Now scribe a line around the outside of the cylinder bore onto the head. That should give you an idea of what your looking for. It should show how close that big intake valve is to the bore, etc.
Merry Christmas by the way.
D.J.
D.J.
