LS2 Knock sensor Thread/Pitch Size
Old 05-28-2008, 10:39 AM
Haans249's Avatar
Default LS2 Knock sensor Thread/Pitch Size
Hello All,
I've got to put in a LS1 knock sensor in the LS2 block knock sensor location. I already know that the hole needs to be tapped to M10x1.5 hole size, but when the motor was assembled, it was forgotten to tap the hole to the proper size. There are other knock sensor locations right above where those holes are, and that is where I currently have my knock sensor (LS1 application). Problem is they are too close to the headers, and one of them had a melt down. I can't remove the old knock sensors because the headers are too close to them, and I can't tap the holes because there isn't enough room. The only option I have right now is to resize the thread of the LS1 knock sensors. What size is the LS2 knock sensor thread?
Thanks,
Adrian
Old 05-28-2008, 11:21 AM
69LT1Bird's Avatar
M8x1.25x40, 22 Thd, 18 Od, 8.8
Old 05-28-2008, 12:15 PM
Haans249's Avatar
Thanks for the thread size! But there is no way I'm going to be able to re-thread those knock sensors. The pitch is different, which would just mess up the thread. Thanks anyway....guess I'll have to figure out a way to get in there and tap that hole...
Thanks!
Adrian
Old 05-28-2008, 01:36 PM
Haans249's Avatar
I lied, I just ground down the original threads, and then put the die to it, first time ever, and man is it a pain in the ***!! I hope it works.....
Old 05-28-2008, 01:48 PM
lt1camaro95's Avatar
I am glad my engine was out when I did that.
Old 05-28-2008, 03:04 PM
Haans249's Avatar
LOL, no kidding, mission accomplished, went right into the stock LS2 sensor location, the re-threading of the LS1 sensor worked! Now I just hope that it registers in the PCM and the sensor actually works. Otherwise i'll be rather dissappointed haha.
Alright, off for some tuning!
Old 08-01-2008, 02:18 PM
rufretic's Avatar
Did it work? I'm going to have to do the same thing
TIA
Old 08-02-2008, 04:43 PM
BigDB's Avatar
can u post pics of where the sensor needs to be. I have a LS2 block on the stand and I put my LS1 knock sensors behind the motor mounts. They threaded right in, im wondering if I need to move them
Old 08-02-2008, 05:34 PM
HSV-GTS-300's Avatar
"Same both sides" means walk around to the other side of the engine and do the same thing there.
Old 08-02-2008, 07:23 PM
rufretic's Avatar
The alternative doesn't work with 1 7/8" headers, I found out the hard way.
Old 08-21-2008, 06:06 PM
BigDB's Avatar
do the sensors work?
Old 08-21-2008, 07:22 PM
Haans249's Avatar
yes they are installed and working.
Old 09-03-2008, 02:35 PM
ZDOG's Avatar
am i looking at this right? your alternative arrow points to a engine mount hole?
Old 09-03-2008, 07:18 PM
Yes, some mount brackets only use 3 of the 4 holes.
It's not a good solution, but may help somebody that forgot to tap out the LS2 knock bosses.
Old 11-02-2013, 01:44 PM
bad6as's Avatar
TTT
im getting ready to do a gen 3 to gen 4 block swap. i do not have motor mounts because i have motor plates in my car. does any one know the thread size for the 4 motor mount bolt holes? and even tho the sensors are susposta go in the "normal" hole in the picture does it really make a differance if they get installed in the motor mount holes?
Old 11-03-2013, 03:51 PM
It's written in green in the bottom right of my picture.
M10x1.5
Old 11-03-2013, 05:42 PM
bad6as's Avatar
Ahh duh. So any one think using the motor mount holes would be any different then the knock sensor holes?
Old 11-06-2013, 08:09 AM
KRAZY K 2000 TA's Avatar
when you say working does it show anything when you use the scanner that reports it actually showing knock thats real???
Old 03-03-2021, 12:17 PM
MJ 27's Avatar
Default Knock sensor relocation
Does anyone know the size of these threaded holes? I am trying to put the knock sensor for an ls2 on the side of the block but need to find a mounting stud to make it work... thanks! Michael
This is what i am trying to do...
Quick Reply: LS2 Knock sensor Thread/Pitch Size
