is l76 and ls3 intake the same?
LS1Tech Premium Sponsor
They are virtually identical, except the LS3 intake has that beauty cover whereas the L76 does not. Only the complete assembled intakes (with rails, injectors and TB) were discontinued. There are still plenty of bare intakes available and shipping daily
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Doubtful.
The mounting holes for the fuel rails on the LS2/LS3/L76 intakes are wider apart than LS1.
Also LS1 fuel rails are normally set-up to accomodate LS1 length injectors which are much taller than the LS7 injectors found in L76 intakes.
Curvature of a stock LS1 fuel rail and bracket heights on non-stock LS1 fuel rail will be all wrong.
See here
LS2/L76 fuel rail sitting on a FAST LS1 style intake.....notice fuel rail bracket width difference.
See here
I have a few of these map sensors cause I used to work for the company that makes the LS3/L76 Intake. The intake itself is injected molded/lost core in Frankfort KY. Made by Montaplast of NA.
