true street rules
Old 08-14-2012, 09:40 AM
sleeper101's Avatar
Default true street rules
I read the rules and I'm confused on tires. in the advertisement part it states a dot legal tire. in the rules it says a true 10.5 tire. can we run a 10.5 slick?
Old 08-14-2012, 10:01 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
DOT tires only.
Old 08-14-2012, 10:24 AM
sleeper101's Avatar
So what class would my 240 fall under since real street is a gm chassis only class? I got a single power adder and 10.5 slicks? its a true street car. I drive it everywhere. I just don't have no drag radials.
Old 08-14-2012, 03:23 PM
s14blane's Avatar
6.D.O.T. Radials or D.O.T. Slicks on front and rear of vehicle.
Taken from the following link on the LS fest website:
http://www.holley.com/data/Pages/LSF...et%20Rules.pdf
Old 08-14-2012, 05:33 PM
1994z's Avatar
rumble class. if you have the time and money get a set of drag radials have them mounted on your wheels, run the true street class on sat. after the last pass take them to town and have them swap over to your slicks. if you want to go thru all that.
Old 08-14-2012, 09:46 PM
sleeper101's Avatar
Ya not really wanting to go thru all that trouble. Maybe someone will let me borrow some radials.
Old 08-15-2012, 02:14 AM
buick_lsx's Avatar
What's your bolt pattern and back space for the 240? And what size wheel
Old 08-15-2012, 06:10 AM
sleeper101's Avatar
4lug 4.5 bolt pattern. I'm using a universal mustang weld drag lite wheel 8in with 5.5 back spacing.
Old 08-15-2012, 12:31 PM
LS1Tech Co-Founder
What size slick are you running? Maybe someone has some DOT's they will sell cheap.
Old 08-15-2012, 01:55 PM
sleeper101's Avatar
Old 08-16-2012, 08:44 AM
s14blane's Avatar
There will be a tire changer on site for those who need to utilize that service. $10 a tire including tire disposal.
Old 08-16-2012, 03:35 PM
BLNLS1/RX7's Avatar
Originally Posted by sleeper101
26-10.5-15
I might have a set of Hoosiers that size.I will chech.
Old 08-17-2012, 08:53 AM
s14blane's Avatar
I don't quote myself often but thought it important to mention that though the tire changer will be there he will not have access to a balancer, which makes this more inclined to the low speed events.
Old 08-17-2012, 04:16 PM
sw07gt's Avatar
DOT slick tires or DOT legal radials tires required for drive tires during the road tour AND the True Street competition and class run off. Racing slicks prohibited. Maximum actual measured tire size is as follows: Actual measured tread of all racing slick-type tire is limited to 10.75-inches. For D.O.T. radial tires, maximum sidewall designation permitted is 325mm.
I'm a little confused here, what qualifies as a dot slick tire vs a dot radial? Basically I'm trying to figure out if my 295 ET Streets are legal.
Old 08-17-2012, 06:39 PM
buick_lsx's Avatar
et streets? 3 grooves in the tread?.....LEGAL, they will have a dot number on them as well
Old 08-18-2012, 01:47 AM
Alvisracn's Avatar
I believe I have a set of those, if you can find some tires, I will check to make sure I have them and bring them with me.
Bill
Old 08-18-2012, 07:16 AM
sleeper101's Avatar
Bill
Sounds good man. I got a buddy here that has a set of radials on his truck he says I can borrow. so I should be ready I think lol.
Quick Reply: true street rules
