Go Back   LS1TECH > NATIONAL EVENTS > Hot Rod Power Tour/ Pump Gas Drags/ Drag Week
Sign in using an external account
Register Forgot Password?
Register iTraderTimeslips Photos Members Search Today's Posts Mark Forums Read Vendors
Search
Hot Rod Power Tour/ Pump Gas Drags/ Drag Week Covers all Hot Rod events
Welcome to LS1Tech.com!
Welcome to LS1Tech.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join LS1Tech.com today!
Thread Tools Search this Thread
Old 11-07-2011, 06:15 PM   #1
Garage is empty, add now
Trader Rating: 0
Default power tour
leaving out of my home town Detroit can't wait going to do the long haul 02 Z28 402 stroker going to put all the street tires back on and go
__________________
02 z28 402 stroker direct port injected nos 200 hit stand alone fresh numbers N/A
LS12GO is offline   Reply With Quote
Old 11-29-2011, 08:42 PM   #2
luvmeZ28's Avatar
Trader Rating: 3
Me and a buddy plan on doing the long haul from dfw to detroit, then back again. gonna be in my stockish 99 SS.
luvmeZ28 is offline   Reply With Quote
Old 11-30-2011, 04:21 PM   #3
Trader Rating: 0
Quote:
Actually it is the other way around, Detroit to Arlington. I hope to get in with a group going up there together and doing the long haul.
__________________
Craig
2002 Arctic White SS, #4675, M6, LS3
LS7 Clutch, Kooks headers, Corsa Cat-back, !CAGS, !AIR, B&M Ripper, S60 w/ 3.73s.
A modded V8 when started "sounds as if you stepped on some large animal in a dark cave. It awakens agitated".
Arctic2002ss is offline   Reply With Quote
Old 12-01-2011, 04:55 PM   #4
gocartone's Avatar
Trader Rating: 3
Quote:
He means he's going from Texas up to Detroit before it starts and then back with the tour.
Would love to do the long haul but I doubt any of the people I'm going with will want to. I will be on the first three or four stops for sure (hopefully in a C5Z06 by then ), but after that I think everyone in my group will be headed back home.
__________________
2008 JSB C6 485whp/445tq
gocartone is offline   Reply With Quote
Old 12-01-2011, 07:19 PM   #5
chazzychaz's Avatar
Trader Rating: 31
I'm planning on doing the hike from TX to MI then back down again with the tour as well
__________________
Chaz
2000 Camaro v6: beater [Gone]
2000 Trans Am WS6: VRX4 cam, stock 241's, MWC 9" w/ spool and 4.11's. 380/360. 7.73@93 1.82 60' [RIP]
2000 Trans Am: 26k miles, stock... for now
2002 Camaro RS: new beater
chazzychaz is offline   Reply With Quote
Old 12-02-2011, 08:16 AM   #6
whitesmokels1's Avatar
Trader Rating: 4
Quote:
Same here. All of us Texans need to get a group together for the trip to the starting point. It was a long lonely trip to Cocoa Beach last year.
__________________
1998 Corvette. Black targa six speed. heads&cam.
1979 Camaro Z28. 5.3L/4L60e swap, p&p 241's, comp 1.85 rockers, comp timing set, yellow springs, p&p oil pump, '01 LS6 cam, currently installing a TT setup. Full air ride, posi, c5 wagon wheels, 2.5" cowl hood.
1997 ECSB, Solid front axle swap, 38" Baja Claws, 4.88 gears.
2006 R1. caged, power commander, gp reverse shifting.
whitesmokels1 is offline   Reply With Quote
Old 12-02-2011, 06:56 PM   #7
luvmeZ28's Avatar
Trader Rating: 3
How long of a drive is it up there I wonder? Time is going to be a bit of a problem for me, so my buddy and I are thinking of just tearing *** up there nonstop, resting for the rest of the day/night before it starts in detroit. Anyone else gonna try to make it up there with no overnight stops? If so we are probably down for a convoy.
Old 12-03-2011, 04:38 PM   #8
Trader Rating: 3
My brother and I are going up also from D/FW to Detroit and back. I will be in my bolt-on 2003 Electron Blue z06 and he will be in his 2004 Torrid Red GTO. We will be down to travel in a convoy from here to Detroit if we can all get a group together
__________________
2003 50th EBM z06
TXTA is offline   Reply With Quote
Old 12-03-2011, 05:29 PM   #9
gocartone's Avatar
Trader Rating: 3
Google maps puts it at about 20 hours, I would plan at least one stop if I were you.
__________________
Old 12-03-2011, 07:11 PM   #10
luvmeZ28's Avatar
Trader Rating: 3
20 hours shouldn't be bad with two drivers in one trip. I've done many 1k+ mile trips, some where I was the only driver. Early registration opened today!
Old 12-03-2011, 07:38 PM   #11
gocartone's Avatar
Trader Rating: 3
Just signed up for it, wish they would let us know what all the cities are already.
__________________
Old 12-05-2011, 05:14 PM   #12
Trader Rating: 0
Long hauling from Tulsa OK to DEtroit and then to Texas. unofficially, looks like the stops listed on the Pwr Tour forum are: Detroit, Muskegon, MI, Champaign IL, Collinsville, IL, TBA, then Stillwater OK and Arlington. Check out www.hotrod.com and go to Power Tour forum for update info.
__________________
70 Camaro
406/426HP
700R4, 3.42 posi
Restified thru & thru!
02 Camaro SS 35thLE, bone stock, T-tops, Build #751,SLP #2175
Tulsa OK ~ Boomer Sooners!
maromoma is offline   Reply With Quote
Old 12-06-2011, 08:38 PM   #13
2001 Chevrolet Camaro
spdygon's Avatar
Trader Rating: 1
Son and I had a blast last year. hope things work out this year. if it does will be long hauling. till then.
__________________
Build #3240 01 ss camaro m6, slp cold pack, 80mm bbk tb, 85mm slp maf, dynotech lt with highflow cats and y pipe,
slp duel/duel, bmr lca, spohn adj torque arm, spohn adj panhard bar, strano full suspention kit with adj konies, stainless steel brake lines, 600f motol brake fluid, hawks brake pads, brembo sport rotors, front brake cooling ducks,tuned by vengeance, 356whp/362tq
spdygon is offline   Reply With Quote
Old 12-06-2011, 09:01 PM   #14
2002 Pontiac Trans Am
Trader Rating: 0
Send a message via AIM to btownws6
how much is it to register?
__________________
2002 Pontiac Trans Am WS6
1989 Pontiac Trans Am GTA
1998 Chevy Malibu
btownws6 is offline   Reply With Quote
Old 12-06-2011, 09:52 PM   #15
gocartone's Avatar
Trader Rating: 3
$83.50
__________________
Old 12-06-2011, 10:04 PM   #16
xX-Z28-Xx's Avatar
Trader Rating: 4
No Iowa... what are the dates?
__________________
Hugger Orange. A4. Lid. Magnaflow. 58K.
Quote:
Originally Posted by Pipeless416 View Post
the beginning makes me want to head butt nuns.
xX-Z28-Xx is offline   Reply With Quote
Old 12-07-2011, 07:33 AM   #17
yarite57's Avatar
Trader Rating: 1
Did it 2011 What a great time, had lots of fun, Flat front runner LOL, than had to buy rear tires in Mi. the drag radials were no fun in the rain. WE will be doing it again in 2012.
yarite57 is offline   Reply With Quote
Old 12-07-2011, 08:27 AM   #18
Mumbles's Avatar
Trader Rating: 3
Quote:
xX...
The dates are June 2nd thru June 9th, but it doesn't look like it'll be coming through Iowa in 2012.
The wife and I will be joining from the kick-off in Detroit and stick with it to the Champaign, IL Venue. We may continue on to the 4th Stop, but I don't think we'll be Long-Haulin' it this year.
I'm glad the first two stops are repeats of the last two from 2011. Those are the ones we missed last year.
__________________
1999 Firebird Formula
M6 Hurst-Billet Short-Throw, Monster Level 3, TICK Adj. MC|SLP Airlid, Smooth Bellows, Polished TB, LS6 Intake|Jet Hot LTs, Catted Y-Pipe, SLP Loudmouth|SLP Subframe Connectors, Spohn Adj. Torque Arm, LCAs
Mumbles is offline   Reply With Quote
Old 12-08-2011, 07:23 PM   #19
2000_SS's Avatar
Trader Rating: 23
I'll be doing the Long Haul with the gf again in the SS.....all you Texans and Okies can meet up with us in Joplin if you want
__________________
2001 SOM SS
Old H/C/I LS1 #'s: 452/395 - LSX 454 T56 9"BUILD THREAD HERE
2000_SS is offline   Reply With Quote
Old 12-08-2011, 07:46 PM   #20
xX-Z28-Xx's Avatar
Trader Rating: 4
Quote:
Originally Posted by Mumbles View Post
xX...
Hey man, good to hear from you! I'll sen you a PM here in a bit...
I may look into this, but don't want to drive to Michigan, there are wolverines up there.
Where's Champaign at? How far from the border is it?
Will you be in the new (to you) formula next year? I'll talk with you in a PM, so I don't get a hijack.
__________________
LS1Tech
Pontiac Firebird
Paid Advertisement
Tags
2012, buffalo, casino, collinsville, day, gateway, hot, ill, madison, motorsports, opening, park, power, powered, rod, run, speed, television, tour, vbulletin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.5.2
Advertising - Terms of Service - Privacy Policy - JOBS
Emails & Contact Details
