N20 on Stock LT1
Old 10-14-2008, 03:24 PM
94CamaroZ28SS's Avatar
Question N20 on Stock LT1
I tried a search couldnt find anything!
my car in sig........i want to possibly hook up N20.
The internals are stock!
what kit should i go with and what is a good amount to shoot on a stock motor? what is WET and DRY Kit?
Are they hard to hook up?
Old 10-14-2008, 03:26 PM
porksoda's Avatar
When I purchased my kit I knew nothing about nitrous! This read really helped me out: https://ls1tech.com/forums/nitrous-oxide/846230-everything-nitrous-related-stock-bottom-end-all.html
Old 10-14-2008, 03:31 PM
Originally Posted by porksoda
When I purchased my kit I knew nothing about nitrous! This read really helped me out: https://ls1tech.com/forums/showthread.php?t=846230
thank you i am going to read through it now..........lets see how well i can remember since im all doped up on tylenol with codiene!
Old 10-14-2008, 03:32 PM
Elliott's94Z's Avatar
This is the best kit for our cars no doubt!
http://www.nitrousoutlet.com/catalog...roduct_id=2809
Old 10-14-2008, 03:36 PM
slomarao's Avatar
dont run a dry kit on a LT1, not a good idea. The computer cant keep up with the juice, so all the kits out there raise the fuel pressure to provide the extra fuel. The stock injectors were never meant to do anything like this. This is the main reason why i wouldnt go dry with a LT motor. LS, they are fine, LT no way.
The limit for LT1's is a 150 shot, people go higher but there are many risks involved. I would say a 150 shot is okay provided your going to buy all the safety items needed.
The install isnt too bad if you know what your doing. But if not you may want to get a buddy whose handy or take it to a shop. I personally dont do my own kit, a buddy does my work because it am not confident in myself. I would advise something similar if you dont want to give it a go.
I would go with a kit from Nitrous Outlet. They will work with you to make sure you get what you want. I have spoke with Ray and Dave there, both are stand up guys.
Old 10-14-2008, 03:41 PM
porksoda's Avatar
I went with HSW and the guys helped me constantly! My entire kit is from HSW and they helped with every question I had before and after purchase, Like I said I knew nothing about nitrous when I purchased the kit, I had bought it because HS had a huge christmas sale. LOL With that being said I got my window switch from Nitrous Outlet and they helped too.
EliteCamaro94's Avatar
Im interested in this, is the link you posted for everything u would need to safely install the kit onto an lt1 car??? Im lookin at buildin my motor with le2 head and cam with full bolt ons and suspension mods and stuff in a few months here hopefully. If i can safely add juice without worrying about blowin my motor sky high i might actually look into it.
Old 10-14-2008, 03:43 PM
He can run a dry shot with the right goodies to go along with it, but the wet is def the way to go. There are some things you will have to do when running a 150 shot or higher. IMO I say go with a 100 shot just to be safe on the bottom end. Nitrous Outlets Plate systems are rated at the wheels. With what you have done to your car going by your sig, a 100 shot will be more then enough to spank pretty much anything on the road!!
Old 10-14-2008, 03:44 PM
BlackTTC6's Avatar
WET kit
Old 10-14-2008, 03:46 PM
porksoda's Avatar
That kit does have everything you would need. Anything after that would just be bells and whistles.
Old 10-14-2008, 03:49 PM
You would want to get the bracket that mounts the bottle where the spare tire and jack go. Also the panel that mounts in your ash tray is another thing I would look at too. The bottle braket is like $50 bucks and $59.99 for the ash tray panel.
Old 10-14-2008, 03:59 PM
hmm thats cool ill definitely keep this in mind for after my motor is built up a bit and i have all the bolt ons and stuff. Good thread guys.
okay so im thinking 75 shot i dont want to get to greedy ya know and blow the motor i just want that little extra!
So from what i read the DRY kit is easy to install, but everyone says go WET?
Can i go DRY? I am pretty mechanically inclined i do all the work on my car and had no problems with anything i have fixed!
Old 10-14-2008, 04:15 PM
You can go dry but from what I undersatand it's not as efficiant power wise and some other downfalls as far as what you have to do to run it..call Nitrous Outlet and talk with them. They kick ***!
Is this a good kit?
i ahve always purchased everything for my car off ebay and never had a problem!
http://cgi.ebay.com/ebaymotors/Brand...mZ370090141210
Old 10-14-2008, 05:58 PM
LM97Z's Avatar
Originally Posted by 94CamaroZ28SS
Is this a good kit?
That kit will be fine, even though its a brand X, its still good, but awhole lot cheaper.
Old 10-14-2008, 06:20 PM
lt170chevelle's Avatar
man people always say dry kits are dangerous..and they are not. i wouldnt run a 200 shot dry but have sucessfully ran a 125 shot for more than a year with not one problem..just make sure you run premium gas, get a step colder spark plugs gapped at 035-.040 and you will be set. and put your nozzle before the maf..
Old 10-16-2008, 10:31 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
Is this a good kit?
That kit is a Nitro Dave's kit
and dry kits are no easier to install than a wet kit.
Old 10-16-2008, 01:09 PM
YORK_MUSTAINE's Avatar
Go For A Wet Shot For 100hps Or 75 But "wet"
If You Dont Have Time To Buy Your Tr6 , Put Yours Tr55 At 0.040
And I Recomend A Ignition Box 6a Or 6al
And Let Me Know Your Time In Sacramamento Raceway
Old 10-16-2008, 01:28 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
please, please, please do not run Tr55s on nitrous....its just not worth the risk.
TR6s or equivalent can be picked up at any local parts house or can be ordered with your nitrous kit.
$16 plugs or $XXXXX motor
Quick Reply: N20 on Stock LT1
