Can I use stock bolts with Spohn Kmember?
Old 10-14-2008, 07:59 PM
Monello's Avatar
Default Can I use stock bolts with Spohn Kmember?
Just bought a new Spohn K Member and I didnt get the bolts with it.
Can I reuse the stock ones for bolting it into the car?
Also, what are the specs for the bolts for the motor mount?
Thanks
Old 10-15-2008, 07:48 AM
Cap'n Pete's Avatar
I re-used the original bolts when I installed my UMI K-member. Torque specs are something like ~107 ft-lbs for the 4 main bolts, and ~93 ft-lbs for the 2 smaller rear bolts. I've double checked the torque on mine a few months after the fact, and it's still as tight as the day I installed it .
What spec do you need for the motor mount bolts? Torque?? Tight!!
Old 10-15-2008, 08:15 AM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
We don't supply new bolts with our k members. We suggest reusing the stock hardware.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 10-15-2008, 09:03 AM
Monello's Avatar
Thanks for the replys guys.
Only reason I am asking is because they list on their website that they supply new 12mm 10.9 Grade bolts for the kmember.
Includes (6) new 12mm Grade 10.9 k-member mounting bolts and heavy flat washers
I will give the stock bolts a try. Cant see why they wouldnt work. =)
Old 10-15-2008, 12:08 PM
fly pantera's Avatar
weigh the k member please.I want to see what the differnce is
Old 10-15-2008, 01:48 PM
Monello's Avatar
Will do =)
Im curious myself to see what it weights.
Old 10-19-2008, 01:08 PM
candlelit's Avatar
just curious, have you weighed the k members yet? what was your purpose of switching to the aftermarket k member after the turbo build?
Old 10-19-2008, 04:00 PM
Monello's Avatar
I think the scale I was using is a little off.
But the spohn showed up as 26 pounds, and stocker was 42 pounds.
I switched to this kmember for added room around the turbo piping. Also the ability to drop the pan without having to drop the kmember is a huge plus =).
Besides, the stock kmember blocks you from doing anything under the car, now with the new kmember I can reach anything.
Old 10-19-2008, 06:57 PM
candlelit's Avatar
good thinking! I noticed a guy having mentioning, even after his heat wrap, a pipe (kit designed by the same ebay seller) was starting to melt another line. Have you had any close calls, anywhere on the car, with heat?
Old 10-20-2008, 08:36 AM
Monello's Avatar
Nothing has really melted yet. I have only ran the car for about 500miles.
I will say that with the spohn kmember everything looks very nice, and everything is so easy to get to now.
I can even replace my passenger O2 from the passenger side wheel well now lol.
Old 10-20-2008, 10:16 PM
exodus's Avatar
I have heard some people say that it's not good to do a tubular k member on cars that see regular street duty, any comments or oppinions on this?
Old 10-21-2008, 08:44 PM
Monello's Avatar
No comment........
lol, we will see how it holds up on the street. =)
