went to the track (times inside)
Old 10-18-2008, 03:00 AM
94LT1Bird's Avatar
Default went to the track (times inside)
went to the track for the 2nd time ever the other night....not the best night but still ok.....
no one was hookin on the track...kind of a dissapointment....
only got 4 runs in bc they took forever doin the bikes and dragsters
run 1
rt .386
60 2.078
330 5.851
1/8 8.942
mph 80.22
1000 .000 <--- thats weird
1/4 13.843
mph 99.6
run 2
rt .470
60 2.047
330 5.822
1/8 8.900
mph 80.26
1000 11.554
1/4 13.799
mph 99.28
run 3
rt .302
60 2.080
330 5.822
1/8 8.873
mph 80.66
1000 11.513
1/4 13.753
mph 98.56
run 4
rt .712 <-- i went to stall it up and realized my lights were off...by the time i look back up the third light just came on
60 2.009
330 5.751
1/8 8.795
mph 80.80
1000 .000
1/4 13.660
mph 100.41
was hopin for a 13.5 but i guess thatll have to wait
Old 10-18-2008, 08:40 AM
Goat2NV's Avatar
Nice times, wouldn't you be a little quicker with a lil more stall??
Old 10-18-2008, 10:37 AM
Smokinlt1's Avatar
a stall would help if he could hook.
What tires r u running? 2.0 60ft on street tires isnt that bad. a 1.9 would give u your 13.5 slip.
Old 10-18-2008, 11:27 AM
94LT1Bird's Avatar
stall is next mod....ima go around 3000
im runnin the cheapest street tires that the store had
Old 10-19-2008, 01:48 PM
MonmouthCtyLS7's Avatar
Yea thought you would have ran quicker myself...thats usually what a auto cars w/ a few bolt ons runs
Old 10-19-2008, 02:34 PM
AChotrod's Avatar
trap speed seems low, but the ets are good
Old 10-19-2008, 02:38 PM
meanredZ's Avatar
Have you done a complete tune-up?
Old 10-19-2008, 02:52 PM
Moderator
BizZzatch350's Avatar
Whats all done to the car, with any auto, trap speeds suck. My car when it ran 12s with bolt ons was only trapping 102MPH.
Old 10-19-2008, 05:05 PM
registered user
ScreaminRedZ's Avatar
With similar mods my autos were trapping 104-105 unless it was hot out. I'd say that something is up power wise (or the shift points are off).
Definitely good times for the mods. I'd be getting some drag radials ASAP, though.
Old 10-19-2008, 06:33 PM
hashtagBMW
Speed Density's Avatar
Ahahaha, I agree with that. I went 13.40 @ 94mph once. lol.
Old 10-19-2008, 08:23 PM
94CamaroZ28SS's Avatar
**** you ran some good times in my opinion 13.6's I WISH!!! I do believe you can hit the 13.5's though!!
i ran 13.8 @ 101 MPH in with bolt ons and the car missing a little bit (bad plug wire) I have 2.73's with no stall.
My next mods are 3.73's and a stall. I just ordered a MadTuner PCM that should be here shortly well see what i pull then.
Old 10-20-2008, 09:02 AM
BigZee71's Avatar
I have a 93Z auto with the hotcam kit and tune, Hooker lts, cai, and 2.73's w/DR's and I
only could manage a 13.6 /104 mph with a 2.1 60. I ran the same time twice never shifting out of 2nd gear trapping at 6100 RPM.
I think your times are pretty decent. A stall and DR's could put you in low 13's high 12's.
Old 10-20-2008, 10:54 AM
slomarao's Avatar
get some sticky tires.
Old 10-20-2008, 11:38 AM
lifeisgood's Avatar
you have to be spinning a lil.
Old 10-20-2008, 12:27 PM
94LT1Bird's Avatar
i was thinkin about gettin some drs next....but since i wasnt spinnin at all i dont think ill need them until i do the stall....which ima ask for for xmas....next on the mod list is rear suspension because something back there is squeakin (not springs) is sqeaks side to side not up and down....and i can feel it sway a lil when im driving....
Old 10-20-2008, 09:29 PM
yeah i spin a bit out of the hole!
Old 10-20-2008, 11:56 PM
snk-huntr's Avatar
not bad for your mods
Old 10-21-2008, 12:43 AM
94LT1Bird's Avatar
when i had 2.73s traction was never an issue
Old 10-22-2008, 10:33 PM
yeah i spin out of the hole a lot before i installed the LCA's and Panhard bar now the car sticks! i have to get back to the track with the new setup! hopefully here soon!
I am also installing the new PCM from MADTUNER i recieved today hopefully that will help out a lil bit!
Old 10-22-2008, 10:40 PM
impaled's Avatar
you would do exponentially better with stickier tires, a stall, and some suspension work. some good LCA's and shocks should help out on the spinning issue. you could really cut that 60' time down with the things mentioned above.
Quick Reply: went to the track (times inside)
