lq4+powerglide...
lq4+powerglide...
i am planning to swap a lq4 into my datsun drag car. it currently has a glide bolted to a 355 sbc. what does it take??? what flywheel would i use? thanks in advance...
damn it could a mod move this to the right section sorry i am a newb!
The powerglide bellhousing will bolt up....
There are some differences with flexplate and torque convertor....some companies make a torque convertor to bolt up to the LSx style flexplate or a flexplate/spacer to bolt up to the existing torque convertor...
LS1 Flexplate Spacer 12563532
http://www.crateenginedepot.com/stor...2-P1343C0.aspx
LS1 Flexplate Spacer Bolt 12563533
http://www.crateenginedepot.com/stor...3-P1344C0.aspx
Though the LQ4 will probably already have this installed since the 4L80 is used behind it and requires the spacer setup.
