clutch pedal stuck!!!!!!!!!
Wat up!!! So was reversing the car out the driveway and suddenly it shut off as if i had poped the clutch out but i didnt........the reverse was stuck and the clutch pedal got really really hard....i was able to pop it out of gear but the clutch staied hard, any ideas or suggestions??????
As they said your T/O bearing or your master cylinder/slave cylinders are shot. Check your clutch fluid level and if you are not able to even move the pedal it's prob your M/C as it is seized, happens when over time moisture rusts the piston. Easy fix, you just have to be gumby when crawling under the dash to unbolt the old one. Let me know if you need any advise replacing it as I just did mine bout 8 months ago.
