clutch pedal stuck!!!!!!!!!
Old 10-22-2008, 01:47 AM
SJblackLT-1's Avatar
Question clutch pedal stuck!!!!!!!!!
Wat up!!! So was reversing the car out the driveway and suddenly it shut off as if i had poped the clutch out but i didnt........the reverse was stuck and the clutch pedal got really really hard....i was able to pop it out of gear but the clutch staied hard, any ideas or suggestions??????
Old 10-22-2008, 04:14 AM
96lt1m6's Avatar
either your hydraulics took a dump or your T/O bearing is toast..
Old 10-22-2008, 06:46 AM
~BuMps AloT~'s Avatar
Beating your throw out bearing is out. Same thing happened to me!
Old 10-22-2008, 07:04 AM
DAVE00's Avatar
As they said your T/O bearing or your master cylinder/slave cylinders are shot. Check your clutch fluid level and if you are not able to even move the pedal it's prob your M/C as it is seized, happens when over time moisture rusts the piston. Easy fix, you just have to be gumby when crawling under the dash to unbolt the old one. Let me know if you need any advise replacing it as I just did mine bout 8 months ago.
Old 10-22-2008, 08:44 AM
Yea i was told it could be the master, all my gears go in fine still so they eliminated the slave. . .an my clutch was grabbin fine be4 it did that so the said that the T/o should be good also. just wanted get u guys opinions and advise be4 i go doing something else. If you got install instructions that be great. . .id like to get that fix . i ordered the master already gana start there. thanx alot guys
Old 10-22-2008, 08:46 AM
great421's Avatar
When this happened to me (just a couple of months ago) it was my second SPEC 3+ = it exploded; yes at idle, yes, in my driveway too... Good luck!
Old 10-22-2008, 08:51 AM
camar0corey's Avatar
When I had this happen to me the throwout bearing was toast, and like a idiot I forced the pedal down and then had a cracked slave.
Old 10-22-2008, 09:08 PM
so it could be the throwout bearing also??? if thats gone do i preaty much gots to replace the whole clutch or just the bearing??
Old 10-23-2008, 08:54 AM
Depends how it looks in there, everything got screwed up in my case.
Old 10-23-2008, 09:21 AM
96lt1m6's Avatar
the T/O bearing has a lip on it so the fork can do its job and some occasions that lip breaks and causes the T/O bearing to shift off of the disk so it then wedges itself on the input shaft...i will bet the bearing is trashed in this case.
Old 10-23-2008, 10:35 PM
coo thanx guys guess the tranny coming down!!!! **** it! good lookin out!
Quick Reply: clutch pedal stuck!!!!!!!!!
