What head gaskets to use?
Old 10-22-2008, 11:49 AM
98RedBird's Avatar
Default What head gaskets to use?
I'm going with an LS2 stroker 402 with AFR heads and a Procharger F1@15lbs of boost this winter. I will be using ARP head studs but what head gaskets should I be using? What else can I do to help keep the heads on this thing?
Old 10-22-2008, 12:38 PM
Z06PSI's Avatar
Gm Mls...
Old 10-22-2008, 12:55 PM
98RedBird's Avatar
Originally Posted by Z06PSI
Gm Mls...
Really? I just didn't know if the stock gaskets would be able to work under boost or not. I'm still new to this FI thing lol
Old 10-22-2008, 01:14 PM
Photochop's Avatar
Go with the 5 layer gaskets...and do a search!!
Old 10-22-2008, 05:42 PM
MY99TAWS6's Avatar
I am using gm ls7 mls.I think they are only three layer though but should be good to 20psi in fact there is at least one other guy running them with good success.If have any problems with them will go to cometic. The cometic work good in my dsms but cometic were twice the price of the gm ls7.
Old 10-23-2008, 05:04 AM
EPP
EPP's Avatar
We use the GM MLS gaskets on LS2 402 builds such as these without any problems. Bob
http://www.exoticperformanceplus.com...Car.php?car=40
http://www.exoticperformanceplus.com...Car.php?car=29
Old 10-23-2008, 08:34 AM
Dumb Ass Vette Moderator
ls1290's Avatar
It is well proven that the GM MLS gasket can handle some big power.
Old 10-23-2008, 08:52 AM
veee8's Avatar
I have the LS7 gaskets as well, now.
I had the cometics on my 6.0L with milled 317's all motor. A few dyno pulls, and 5 passes down the 1/4. When I pulled it down to build the 370, there was evidence that the combustion was leaking past the fire ring in a couple of spots. $150 for a couple of hours of use on a stock NA motor? It seems to be hit or miss with those gaskets.
Old 10-23-2008, 10:43 AM
Dark Shadow's Avatar
i here the same thing all the time with cometics
Old 10-23-2008, 10:55 AM
Fireball's Avatar
5-layer GM MLS here too...have seen 25+ psi so far
Old 10-23-2008, 11:04 AM
so anyone know if we can buy ls9 gaskets yet
Old 10-23-2008, 01:02 PM
eb02z06's Avatar
The 5 layer GM MLS gaskets are are 4.100 bore, if your using AFR 225's they call for a larger bore. What about the Fel-Pro's, they have a 6 layer MLS does anyone carry those?
Old 10-23-2008, 01:18 PM
Photochop's Avatar
Not to *****, but how do the 5 layer 3.90 bore gaskets fare with 6.0 heads compared to the 4" bore ones on a 3.903 bore bottom end (347)? I think my shop gave me the smaller ones when I assembled the motor going by the receipts. Am I in for it or are there any differences?
Old 10-23-2008, 01:42 PM
ss1
ss1's Avatar
I posted this a while back...
6.0 MLS gaskets are 3-layer with a 4.039" bore.
6.2 MLS gaskets are 5-layer with a 4.100" bore.
Compressed thickness varies depending where you look.
Arun, are you saying AFR 225's call for a gasket with larger than a 4.100" bore?
Old 10-23-2008, 01:59 PM
7 Second Club
NicD's Avatar
Use the GM 6.2L 5 layer gaskets. Yes I know the big chamber AFRs list a slightly larger bore gasket but myself and many others run them without any issues what so ever.
Old 10-23-2008, 05:10 PM
MY99TAWS6's Avatar
I still was talking to few guys running the ls7 head gaskets at least to mid teens boost levels with zero problems on the afr 225s. I do think they are only 3 layer but not sure how many layer is as important as the composition of the head gaskets. I also run cometic to pretty high boost like 25 plus psi on my 97 talon without any problems.I did lightly coat them with copper spray on install and have arp head studs. Some guys seem to have great luck with cometics some not so much. I dont' plan on running much past 15psi on my build so hoping the ls7 can do the job.
Quick Reply: What head gaskets to use?
