Notices
WTB: LS1 Block
Old 10-27-2008, 01:05 PM
b3av3r's Avatar
Default WTB: LS1 Block
I am looking for an LS1 block that is in good condition. I need it to have pistons, rods, and crank as I plan to transplant everything from my motor. I would like to know everything is in good working order and wouldn't mind seeing results of a compression and leak down test.
I am in the Baton Rouge/New Orleans area and would prefer local pick up but shipping is alright depending on condition and price.
Thanks
Old 10-27-2008, 01:31 PM
jmoody66's Avatar
Thanks
I will have one for you here either this week or next but its a better block...LS6 out of my 02 Z06...70K miles, its over at a shop in Tomball Tx and due to be pulled hopefully this week and replaced with an LS2 402 forged setup. If you hurry you can drive it and hear it or ask the builder his pro opinion or have an independent come test it. I would take 1300 plus shipping and crating charges if my builder charges that.
Old 10-28-2008, 10:13 AM
Funkster's Avatar
Have one out of my 43K mile Camaro. Will be block and rotating assembly with oil pump, cam timing chain and front and rear covers. $1100 plus shipping.
Old 10-28-2008, 10:14 AM
NastyC6's Avatar
I have a complete ls2 block for 1,300 if you are interested.
Old 10-28-2008, 11:52 AM
jmoody66's Avatar
Oh I guess Im too high.....1200 plus shipping and remember...its a 405 hp Z06 LS6 engine
Old 10-28-2008, 12:26 PM
Funkster's Avatar
Not to bring you down but the only difference between an LS1 and LS6 block is oil passageways I believe.
Old 10-28-2008, 12:56 PM
justinast99's Avatar
Default Engine
I have one I just pulled out it is in good running condition. 71k out of 99 ws6.
900 obo located in oklahoma. pm me
Old 10-28-2008, 03:29 PM
jmoody66's Avatar
No I believe theres more to it...I copied this:
LS6 can also refer to a 454 CID Chevrolet Big-Block engine of the 1970s
The LS6 is a higher-output version of GM's LS1 engine and retains the same capacity. The initial 2001 LS6 produced 385 hp (287 kW) and 385 ft·lbf (522 N·m), but the engine was modified for 2002 through 2004 to produce 405 hp (302 kW) and 400 ft·lbf (542 N·m) of torque. The LS6 was originally only used in the high-performance C5 Corvette Z06 model, with the Cadillac CTS V-Series getting the 400 hp engine later. The V-Series used the LS6 for two years before being replaced by the LS2 in 2006. For 2006, the Z06 replaced the LS6 with the new 7.0L LS7.
The LS6 shares its basic block architecture with the GM LS1 engine, but other changes were made to the design such as windows cast into the block between cylinders, improved main web strength and bay to bay breathing, an intake manifold and MAF-sensor with higher flow, a camshaft with higher lift and more duration, a higher compression ratio and a revised oiling system better suited to high lateral acceleration.
Old 10-28-2008, 04:10 PM
Funkster's Avatar
All true but he isn't getting the main items that improve performance. Wasn't he looking for the short block? In that case the heads, and intake are irrelevant. Most of the increase in power came from those two. If you are including the camshaft then there is a slight difference in the two. As far as the basic short block, there is little difference in the two as far as performance. I was just making the basic point. I don't argue improved oiling and breathing capacity aren't a valuable upgrade. Just stating the block and rotating assembly themselves wouldn't make that same 405 horsepower with 241 heads and an LS1 intake manifold.
Old 10-28-2008, 04:51 PM
stock302mustang's Avatar
check my for sale post
Old 10-28-2008, 07:02 PM
jmoody66's Avatar
Are people still running ls1 intakes? You can get the 6 on the cheap and arent the heads pretty much the same? Either way the ls6 is a better BASE block than the ls1 and its aluminum vs an L98. I would think that in theory the cast windows they put in to better manage windage inside the block would have an effect on your dyno curve...but I dont profess to be the pro at making that assumption...I just look at two vehicles with the same horsepower and tq (same engine) driving into the wind, ones a truck and the others a vette.....which one will do it more efficiently? But hey if he wants the long block then Im open for bids on that one cuz honestly I would rather get a set of aftermarket heads.
Quick Reply: WTB: LS1 Block
