How Many Tenths Do You Drop in the 1/4 mile with a 150 shot
Old 10-28-2008, 01:25 PM
99Ls1fever's Avatar
Default How Many Tenths Do You Drop in the 1/4 mile with a 150 shot
I wanted to figure out or find out how many tenths do people usally gain in the 1/4 with a 150 shot of the line then throught the run?
I have heard .8 tenths for a 100 shot?
Old 10-28-2008, 01:41 PM
SURPRYZ's Avatar
I personally dropped .5 sec off with just a 75 shot. Everyone's cars' are different so I don't know if there really could be a ET drop per shot of N2O? Maybe just a good rule of thumb type answer.
Old 10-28-2008, 01:51 PM
ATVracr's Avatar
The faster you go the less you will gain.
Old 10-28-2008, 02:00 PM
KBG
KBG's Avatar
I dropped a full second on a 125
Old 10-28-2008, 02:19 PM
Midnight02's Avatar
On a bone stock car, it would be possible to pick up over a full second with a 150 rwhp shot. As you get faster, the gains tend to slowly decrease.
There are so many other factors that affect your ET, so it's impossible to say that "a 150 shot will knock a second off of your 1/4 mile time", however all other things being constant, you could expect to be in the ballpark.
Old 10-28-2008, 03:24 PM
1Bad86Gn's Avatar
My GTA picked up 1 second/10mph on a 75 Dry shot.
Car has 3.23's the shot out of the hole was worth over .2 in the 60ft alone
Old 10-28-2008, 07:37 PM
99Ls1fever's Avatar
Thanks guys, I just wounder-ed if there was a rule of thumb? I hope I can get over a second gain with a 150 shot or I guess I will have to run a bigger shot
Old 10-28-2008, 07:46 PM
94lt1m6's Avatar
I just saw a guys sig that said he went from 12.9 to 11.8 on a 75 shot
Old 10-28-2008, 08:19 PM
99Ls1fever's Avatar
Thats awesome man! what are you a M6 or a Auto? never mind I read your screen name. Is it a LT1 with a LS1 in it? or is it on a LT1?
Old 10-28-2008, 08:35 PM
JDP
JDP's Avatar
ya, it all depends how fast your car already is, youll drop more with a 150 shot if your car is close to stock running low 13 as oppose to a 10 second car on a 150 shot
Old 10-28-2008, 08:38 PM
99Ls1fever's Avatar
N/A i am about 520 hp and 480 trq. Havent sprayed yet at the track. I run 12.0's at 5,800 feet in colorado.
somws6bird's Avatar
My car is goofy,
I have full exhaust, TB and Lid= 12.9 at 109-110 weight 3450 a little gutted with me in it
-300lbs+skinnies and 150 shot= 12.0 at 123-124 weight 3150 with me in it
run with the nos it was hard to put it in 3rd and 4th with a horrible launch 2.0 60ft
If I had a new clutch with a better launch I wouldn't be suprised If I pulled off a 11.5
Old 10-28-2008, 08:52 PM
SPLATT's Avatar
was it the guy who posted 2 posts above you?
Old 10-28-2008, 09:10 PM
99Ls1fever's Avatar
Originally Posted by somws6bird
My car is goofy,
What do you think you can get your sixty foot time down to?
Old 10-28-2008, 09:22 PM
somws6bird's Avatar
I still have a 10-bolt so I don't like to lauch hard at the track, I usually get a 1.9-2.0. I really can't afford to dump/slip clutch to high, I need the 10-bolt to last for at least till the spring.
I made a mistake that run was actually a 2.2 60ft even worse!!
Old 10-28-2008, 09:46 PM
99Ls1fever's Avatar
Dam, and that is with spraying of the line? or after 1st gear lock out?
Old 10-28-2008, 09:48 PM
Orr89rocz's Avatar
sucks you have a stick, my 10 bolt held 1.41 and 1.45 60 foots so far and many 1.5-1.6's and a year of 1.7's I got lucky with my stalled auto i guess
Running 11.47 as best on motor with a 1.55 60 foot in kinda warm air, i went 10.72 not spraying off the line with a 1.54 60 foot in cold air. Spraying off the line, i ran 1.45 60 foot and 10.63
thats a 150whp rated shot but i dont think i'm getting the full 150whp. May be close tho, i picked up .84 so far. trap speed went from 118.5 to 127. I was expecting near full second and 10 mph tho
i'm also using like 8 lbs of nitrous for 4 passes... that doesnt seem right to me at all. Maybe 7.5 with the purging but still i thought i'd get 6 passes with full 10lb bottle
Old 10-28-2008, 09:52 PM
99Ls1fever's Avatar
Those are dam good times for a TPI engine
Old 10-28-2008, 11:08 PM
b00sted's Avatar
I only got 3 good passes with a 10# bottle and a 150 shot...
Old 10-28-2008, 11:24 PM
6 & 8 Second Club
mrdragster1970's Avatar
Way to many variables. On my 9.30 car, with N2O gear & converter in there, I picked up .75 with a 150-175.
Quick Reply: How Many Tenths Do You Drop in the 1/4 mile with a 150 shot
