tfs 515 horsepower package
Let me know if you need any advice i can sell you a complete package. This is the one i had in mind.
https://ls1tech.com/forums/showthrea...908&highlight=
Vengeance Racing Heads/Cam Package buit to YOUR SPECS!!!
TrickFlow 220cc "As Cast" 3.90" OR 4.0" Bore Cylinder Heads
Milling of Cylinder Heads to Desired Compression
TrickFlow 7.500 Hardened Pushrods
Vengeance Racing VRX Series Camshaft-YOUR CHOICE
Yella Terra Ultra Lite Roller Rockers
GM MLS Head Gaskets
ARP Head Bolts
GM Front Cover Gasket
GM Front Cover Seal
GM Waterpump Gaskets
FAST Intake Replacement Gaskets
NGK TR55 Plugs x 8
2999.99 plus shipping!!!!
**Upgrade to CNC 215 or 225 TrickFlows for 679.00
**Add Melling Hi Volume Oil Pump for 139.00
**Add LS2 Timing Chain for 39.99
**Add Ported 92mm FAST Intake for 1059.00
**Add either a Ported LS2 90mm TB/Nick Williams 92mm TB/FAST 92mm TB for 369.00
TrickFlow Cylinder Heads power some of the quickest/fastest LSX combos in the country!!! Offering 13.5* Valve Angles over the standard 15* LS1 Valve Angle for increased mid lift flow AND increased piston to valve clearance!! Thicker Rockers Bosses/Extremely thick deck surfaces are two other advantages to this incredible aftermarket casting!!!
Vengeance Racing VRX Series camshafts have proven themselves time and time again to not only lay down the # on the dyno but to perform just as well on the street AND at the track. If you need help selecting a camshaft feel free to call/email/PM. We will spec a cam to suit your needs
GM MLS Head Gaskets
ARP Head Bolts
GM Front Cover Seal
NGK TR55 Plugs x 8
