True Duals Question..
Old 10-29-2008, 10:09 AM
94 s dime's Avatar
Default True Duals Question..
i havent really read anything on this settup.. it crossd my mind last night when i was setting up a parts list to order in the next few weeks... on my 95 z28 do you think it would sound good with pacesetter lt's to an x pipe with 2 lm2 mufflers? i havent heard of this settup yet and was just kind of curious
Old 10-29-2008, 11:14 AM
Green3spd's Avatar
I just bought my hooker LTs an having a hard time decieding on keeping my magnflow catback or goin with an xpipe true dual set up...
Lets see some sound clip...
Old 10-29-2008, 11:15 AM
19mike84's Avatar
i have pace setter long tubes with true duals. it sounds great. it does however, scrape a little bit on uneven surfaces. if you want to buy a kit that will work with a little cutting, tsp makes a true dual kit for ls1's. i know it fits with minor cutting and a little bending of the exhaust hangers.
Old 10-29-2008, 11:41 AM
96lt1m6's Avatar
True duals is just the way to go!
I get compliments all the time on the way it sounds.. you will like the performance gain also,just remember this,if you are a mildly modded Lt1(small cam etc.) you DO NOT need 3" duals 2-1/2 will work the best...........
Old 10-29-2008, 12:01 PM
Restricted User
juicdta's Avatar
here is a video of mine at idle w/ true duals all the way out the back. mufflers are powerstick's
Old 10-29-2008, 12:21 PM
mean_greenZ's Avatar
go for it man! and like these guys said 2.5" is plenty unless you make some crazy power. and it will save you a little money too. for mufflers i like dynomax bullets or the magnapacks.
Old 10-29-2008, 10:51 PM
tspence45's Avatar
I'd say go with some knock-off Flowmaster single chambers off ebay. Here's how it sounds with those. http://videos.streetfire.net/video/9...ust_192864.htm
Old 10-30-2008, 12:49 AM
Kolt@F.A.S.'s Avatar
As long as you dont mind scraping do it!!!
Old 10-30-2008, 02:04 AM
Restricted User
juicdta's Avatar
i have no scraping at all. my lt's hang lower
Old 10-30-2008, 07:01 AM
Purple95Z28's Avatar
It is possible to get it almost the factory exhaust height with true duals!!
That's maybe an inch lower then stock, haven't scraped anything even once
Old 10-30-2008, 08:41 AM
multmigs's Avatar
That setup above looks friggin great, why does no one offer this as a set of prebent pipes, which anyone could hook up to the LT of their choice, add whatever mufflers for the straight section and then add tips to the ends? Couldn't a decent exhaust shop get the bends entered in to a computer system somehow to just keep making the same setup? What did it cost if you don't mind me asking?
Old 10-30-2008, 03:54 PM
94 s dime's Avatar
i love that setup
Old 10-30-2008, 07:01 PM
chief455's Avatar
I have duals after Pacesetters dumped at the rearend.
I hate it. Loud in the car. In the way of my torque arm.Can't just put tail pipes out the back. Mufflers are a worry that low.
I've had 6 other 4th gen cars, all single pipe cat back/dual tail pipes.
I'd like to see a 12 second car run a good y-pipe/cat back that is street friendly and low cost. Swap on a dual header back, X-pipe and tail pipes.
Will the car actually go faster?
Probably gain dead weight with the extra pipes and not much if any power..don't know. A 4" Mufflex y-pipe into a 3 or 3.5" straight pipe into a good cross muffler with 2.5" tail pipes is likley good down to mid 11 second rides.
Anyone want my duals - bring your y-pipe and cat back to my garage ans swap them and it's yours.
Old 10-30-2008, 07:19 PM
3rdgen92maro's Avatar
i vote duals all the way...i have pacesetter LT's, summit xpipe and bullets dumped at the rear. i love it. it sounds awesome way better then any ORY setup. i get compliments all the time on it. however it does hang lower then stock and scrape on big speed bumps and such. i also went with 3in pipe instead of the usual 2 1/2 so that also adds to the ground clearence issue. but all in all its totally streetable.
Old 10-30-2008, 08:04 PM
zlicious94's Avatar
Only way to go!! As you can see the cutouts on the other hand are driving me nuts they scrape on everything Dont recomend cutouts!
Old 10-30-2008, 08:08 PM
chief455's Avatar
hey - can you post up how you have your tail pipes mounted?
thanks -
Old 10-30-2008, 08:10 PM
chief455's Avatar
can you post up showing how your tail pipes are mounted?
Old 10-30-2008, 08:29 PM
Including the mufflers it was about 700
Old 10-31-2008, 12:49 AM
zlicious94's Avatar
Here is the tailpipes
Old 10-31-2008, 10:11 AM
Chevyguy358's Avatar
Originally Posted by chief455
bring your y-pipe and cat back to my garage and swap them and it's yours.
where you live...lol
