Engine wont start
Engine wont start
I built my engine about 1 month ago and installed it with a powerglide swap on my 2000 z28, cam and crank are dot-dot. I just finished and tried to fire her up but she wont, I still havent got a m6 tune but I already did the starter and hatch release mod. It cranks but it wont start, I'd like to get some advice from you people on what the problem may be, especially from those who had done a th350/400 or powerglide swap. I will check some other things tomorrow, meanwhile I hope you can help me out, thanks.
If it is cranking it's most likely not an issue with the tranny swap. You need to check that the grounds are attached to the back of the drivers side head(3 of them), make sure the crank sensor is plugged in(behind the starter on the side of the block), and make sure you have fuel pressure. If all that checks out okay, start looking for blown fuses and bad relays.
LS1Tech Premium Sponsor
Agreed, check those grounds on the back side of the driver's side cylinder head. Do you have a fuel pressure gauge you can look at while cranking to ensure pressure at the rail? Maybe one of those inexpensive spark testers they have for sale at Autozone too? Let's figure out if you're missing fuel or spark or both and that'll make it easier to narrow down the issue!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
I checked all the grounds but the ones on the back of the heads, I forgot to check them last week but I'm pretty sure they're ok since I did all the swap, I'll check them tomorrow and I'll also check fuel pressure and spark, a friend of mine is coming with the right set of tools to check those. I'll let ya know what happened, thanks
Need more info on the setup. Ls1 based? ls2 based?
off the top of my head, if the TPS is not plugged in or wacky the car wont start.
check the grounds 90459350 times. both on the heads, one under the starter, one on the pass fender, one on driver side block.
check fuel pressure
make sure coils are right, that you didnt flip the harness around.
make sure you have the right fuel injector plug on each injector and you didnt swap a couple.
check for the infamous VATS flashing security light
if it's an ls2 swap, make sure you switched the wires on the cam sensor harness.
check fuel pressure
Hey wassup, I checked everything today
Tested spark ok, fuel rails are full of gas, I took off all the IGN, PCM and Fuel relays and they look ok, all the grounds are connected, all the injectors are connected in order, the coils are connected the way they are supposed to be, car keeps cranking but no fire.
I stripped the car about 11 months ago and left gas inside the tank, I know it might sound stupid but I tried to start it with the same gas so I would like to think its either the gas which had lost some of its properties or the injectors are not delivering any gas. I removed the gas tank and emptied it but gas didn't look bad, anyways I'll take my injectors and fuel pump to check and put new gas inside.
BTW as a note: I haven't done the M6 reflash to the PCM, hope you have any suggestions or ideas on what to do next
THANKS
THANKS
