Hesitation - PE Delay? Timing delay?
Upon flooring it from around 50 mph, the car will downshift into second gear, take off, then about 3 tenths of a second after downshifting it feels like it gains 40hp. I noticed it in the past and it is more noticeable now with the colder weather. What could be causing this delay in power? I thought I had everything covered with the torque management being disabled and the PE enable rpm set to zero. what else should i be looking for?
1 Post
Best thing to do is log it and find out... watch timing and commanded AFR in particular... that will tell you if you missed something in one of them. I would suspect timing from what you describe.
ya it does kinda sound like timing huh? i did notice an odd dip in my timing table, i'm going to see if i can get rid of the dip and maybe add more timing at lower rpms. let's see what happens
Moderator
I would more suspect that when you hit into
it, you see a KR blip from the air surge, fuel
add and timing pull may be a bit slow to
cover it. Log for knock retard as well as
total advance, and anything you can use to
determine whether you are seeing a lean
transient at tip-in.
